I've got to the point where i have stripped all parts i need to keep for my build off the car (mx5) and now need to set rid of the body. But
every scrap collector i call to collect the car ask's for the v5
How do i get rid of it without chopping it into little pieces?
Thanks in advance
Firstly you need to find someone who is a registered ATF (Authorised Treatment Facility). You then sign the car and V5 over as being scrapped and you
will then receive a Certificate of Destruction. (I would keep a photocopy of the V5 for your reference as well anyway). When you apply for
IVA/registration, you state the donor car was used and has been scrapped and attach the Certificate of Destruction.
That's the route I took building mine and didn't have any issues when registering my kit
DONT DO THIS. ^^^
It might have worked once, but once a car is scrapped its quite likely to become unusable as a donor.
Cut the shell up or weigh it in as scrap metal, not as a scrap car.
[Edited on 2-8-16 by loggyboy]
Chop it up, only three trips in an estate car
SelfAssemblyMX5
I found someone who was fine to take the shell as just metal, I'd removed all identifying marks to keep the car in my name. I didn't get any money for it, and it did take a bit of searching, but I got there in the end.
Originally posted by loggyboy
Cut the shell up or weight it in as scrap metal, not as a scrap car.
Originally posted by MattD
Have done it twice in recent months at two different recyclers.... just take few photos for "proof" & remove its identity by chopping out the VIN plate(s), and keeping the number plates, V5 and don't forget to keep the vehicle SORN'd.
And I got paid both times, though I did have to take it to them - no chance of it being collected. Steel value is depressing low at the moment too.
And don't forget to declare CATs separately as they are worth extra $$ on their own.
And Alloy wheels/batterys.
Afew months back I weighed in a clio shell and a load of parts - 1.1 tonnes in total - got £30. Weighing in 6 old alloys at same time got me £35! and 1 large battery for £10.
3-4 years ago I weighed in a similar amount of steel and got £300.
I use a website called Freecycle to advertise unwanted stuff. I got rid of a nasty, oily, completely seized, left outside for 2 years engine via it. 10 people offered to come round and pick it up.
Thanks for the advice. Keeping the V5 is definitely a must so i suppose i'll be chopping the cat up into little bits.
Maybe an excuse for some
mor power tools
Originally posted by dwebber597
Thanks for the advice. Keeping the V5 is definitely a must so i suppose i'll be chopping the cat up into little bits.Maybe an excuse for some mor power tools
DONT DO THIS. ^^^
DONT DO THIS. ^^^
Post a message on oval bangerchat somebody will take it.
