Evening all, I'm after some brain-picking regarding Sierra diffs. Before anyone pipes up and says "use the search function", I already
have, and read through the 7th Heaven website, but still can't find a direct answer to my quandary.
I've been offered the rear diff and shafts from a 2.0l DOHC Sierra Sapphire. I'm told it's a 4x4, but am unable to verify this as am
not near the vehicle geographically. I have the vehicle reg number if that helps, but don't want to post here in a public forum as I'm not
the owner of the vehicle. The tag on the diff cover isn't legible. Seller says it has bolt-on shafts, and has sent me the following picture,
that *looks* like the shafts are (rusty) bolt-on Lobro units.
Diff & flange (from rear)
Can anyone confirm whether this is likely to be a 7 or 7.5" unit? I thought 4x4 Sierras used a 3.62 ratio LSD with 100m flanges, but can anyone
offer FACTUAL knowledge please.... Don't really fancy the long journey Sunday to find it's not a LSD, or uses 108mm flanges.
Assuming it's the correct type, I'll be sending away for overhaul (upgrade) - so my standard 3.62 LSD will be for sale in a couple of weeks
if of any interest to people on here.
Thanks!
[Edited on 16/2/17 by Charlie_Zetec]
Ask him to run a ruler over the width of the top mounting as that's either 7 or 7.5.
Can he also run the ruler across the lobo and check that as well?
Bolt on half shafts, 4x4 Sierra my money would be on a 3.65 LSD
Charlie - what diff are you after ? Drop me a text - I've got 5 of these in the workshop in various guise and I'm a lot lot closer
Neil
If it from a 2.0L DOHC 4x4 it is a rare 3.9 viscous LSD
Could be interested in your current one if all pans out with this one.
Neil
Mine came out a 2l twin cam it was a 3,62 open diff the car was a G reg if that helps bolt on shafts 100mm
jacko
