Hi all
Im just about to embark on a new build but i have a couple of questions regarding the donor
I want to use the MX5 but i want to use a lexus engine and there is a good chance it may end up with a BMW gearbox
If i build from this bag of bits will i end up with a Q plate if so how can i avoid this
Thanks for reading
Just to clarify, IVA is not registration, they are 2 separate things.
IVA will only care about engine age (for emissions) and not the source.
For registration, you will need 2 major components from a donor, these dont have to be engine and gearbox, they are just the most common.
You need 2 of the following.
Suspension
Engine
Transmission
Axle(s)
Steering Assembly
Its also unlikely to be physically inspected by dvla as they shut all the local offices so you can always be 'inventive' with your
declaration of where the parts are from.
I'd imagine you'd struggle to get an age related plate unless you built it from the mx5,registered it then did an engine change.But a Q
plate isn't really an issue on kitcars anyway,and I can't remember the last time I saw a stolen recovered saloon or ex army landrover on a Q
either.
A more recently registered Q plate is probably,to me atleast more saleable in the kitcar world now than a pack of lies re-chassis dutton or
something!
Chris
[Edited on 17/4/17 by StrikerChris]
quote:that is what Q reg is (Vehicle of uncertain age), but for kit cars there is nothing wrong with Q reg
If i build from this bag of bits will i end up with a Q plate...
it is also possible to "fit" the lexus engine into the mx5 donor by completing the change of details section of the v5 before submitting it for registration. you will then have a v5 with the correct engine number coming from the donor. Whether you actually fit it in the mx5, no one will ever know!
bearing in mind, the rules say the major components must come from the same donor, nothing says they have to be from the same manufacturer, or that the donor has to be as it left the factory.
Thanks Guys
Thats pretty much as i thought . I think i will register the enginge change to the donor and not worry too mucjh about the gearbox
Thanks again and sorry if i infered that the Q plate issue was an issue at all
Qs have pros and cons, there is a stigma to some that they used on stolen recovered, but that's not going to be held by anyone looking to buy a
kit car.
They also cant have personal plates assigned.
Pros are a slightly easier registration and an easier MoT, specifically on emissions, but IVA requires emissions to suit the engine age so is only a
bonus post IVA.
