Hi,
I dragged home an MX5 for my Haynes project. I'm just about to start stripping it. Just a few questions about the donor:
Originally posted by geedle
Hi,
- I read somewhere that it was a good idea to take photos of the donor and document the parts you take from it. Is this necessary? What exactly should I show? And is this for when I apply for a V5?
- Some suggested that the VIN plate should be removed and kept. Should it?
- When I am done with the shell of the MX5, I notify the DVLA that I scrapped it myself (yellow part of the V5 I think). Will metal merchants take the shell without the V5/VIN and just treat is as scrap metal rather than a car?
Thanks, Geedle.
That's exactly what I needed to know. Thanks.
Just gave the scrap metal place a ring: this one says that they don't care about the VIN plate, so long as I've told the DVLA that I've
scrapped it. And they don't care if it is in one piece or chopped up...
Originally posted by geedle...so long as I've told the DVLA that I've scrapped it. ...
if you want an age related plate, you need to SORN it not scrap it
Right - I think I hadn't understood properly. So I'm SORNing and not destroying the identity of the donor. If I do that, does it not mean that I keep the number plate that is currently on donor? I would like an age related plate rather than a Q plate...
If you report the vehicle as being scrapped now then when you come to registering the new car you can't claim you are scrapping it again as the donor so you will have to SORN the donor, then you can get an age related plate, otherwise it will be a Q plate.
Right - I think I have it worked out now. Good catch - I would have messed that up! Thanks.
I would have thought it would get a Q plate. Can you explain this please?
Just one last question on this... I've nearly got the MX5 shell off the running gear. I want to scrap the shell and it seems that my local metal
merchant will take it without an identity.
It'll likely be a couple of years before I get done with this project (3 young kids!). Is it OK to keep it on SORN when I don't have the
biggest part of the car any more? Can't see why not, but I might have missed something.
Thanks.
Yes correct.
Harvest the vin plates from the shell and take pictures. Other than that, no-one will be inspecting the donor
Brilliant. Thanks. Wife will be happy not to have the rusting shell of a car sat on the drive for two years!
