Hi,
I would appreciate some help....
Are all sierra 4x4 fitted with LSD even the 2 litre versions ?
How can I tell if a diff is actually a LSD
Many Thanks
Hello and welcome,
Cant help with the LSD, but Im in Stockingford, where are you ?
Originally posted by dpnomad
Hi,
Many Thanks
all 4x4s are LSD, unless some locostbuilder has already pinched it...
since the centre diff is another viscous diff
, not only the back wheels
need to be in the air
[Edited on 15/5/05 by JoelP]
Thanks for the info !
another local!!!
I am in Barwell just up the road!
Do you folks come to the nuneaton pub meet (at the former Ansty Arms, now the Raven, I may have met you already if you do!)
I believe LSD has two "A"'s in the middle set of numbers.
Do a search on the forum, as there are some good links to the exact info.
4x4's have LSD.
Two sets of LSD, 7" and 7.5" measures across the back mounting bolt.
7.5"'s are usually granadas or possibly cossies.
search it out, its on the forum,
Originally posted by JoelP
since the centre diff is open,
And unless it's porked you might need a front wheel off the ground too for this test to work properly on a
4x4. shoulda gone to specsavers....
Another viscous LSD actuallyAnd unless it's porked you might need a front wheel off the ground too for this test to work properly on a 4x4.
Liam
If the sierra 4x4 viscous diff is anthing like viscous centre diff from latter range rovers, then as I understand it the, diff is effectively a normal diff, but sealed with a viscouls fluid (a bit like water and corn flour) inside that thickens when sudden force is applied to it, like the diff gears turning. The quiker the gears turn the thicker the fluid becomes.
That's exactly right, and in fact the sierra centre diff/stepoff drive arrangement is borg warner chain very similar to the later Range rover system, BUT............mine seems to be seized to the point where turning one back wheel turns all other wheels on the car. Locking the fronts by dropping them onto the ground and then turning one rear just turns the other rear, but it is then almst impossible to move the rear wheels at all!! (two people job to turn it at all!) no dodgy noises or anything though!
Didn't it worked like
an orange cut in half (and take the fruit out)
then put some fluid in them seal them togetther
and turn on then the fluid with more revs will push the other also..
like clutches is guess
TKS
Just checked my MK (LSD from a 4x4) and I'm in luck, turn the rear wheels and no movement from the fronts!
Cheers Liam!
That all makes sense. I think there is nothing wrong really then. Yes, when you finally persuade a rear wheel to move, it's opposite number on
the back does go the other way with the fronts on the ground.
I think I am somehow subconsciously comparing the XR I have now to my old one which was on it's 3rd time round the clock and evidently the centre
diff wasn't working very well!
As an aside, the XR I have now is actually a pretty good car. I love it as a car but it's just a practical workhorse these days, rather used and
abused but it's a 1990 Flint Grey one, and all original except the ruddy noisy fecking exhaust (Ashley system, cheap, but you need earplugs, only
got it as it was 1/2 the price of a Bosal std system!)
I keep looking at alternatives but I won't spend more than £1500 on a daily driving towcar (much better to spend the money on the 7 and the
grasser!) and I just can't find anything better than the £600 XR at the mo.........................and it seems to be going up in value, the grey
ones are pretty sought after, and it has just gone through it's 3rd MOT in my possession with 0 defects, same as the last 2 years!! The XR's
are the only cars I have had that consistently do that!!
Nat
