Any suggestions where I can get a type 9 gear level. Are there quick shift versions avaliable? Am I just as well going to the scrappies and using an old one? I have a type 9 box plus a remote lever extention
i may have one kicking around but not 100% will check tomorrow and try get bk to you if ya want
Tri
[Edited on 26/7/05 by tri]
i definately have one in the garage if thats any use.
you can easily make your own quick shift see:
http://hometown.aol.com/dvandrews/quick.htm
Mark
The Dave Andrews mod really works, and costs nothing - I incorporated it into my remote shift.
One caution - after making the mod, don't cut your gearlever too short as you lose a bit of leverage. I did, and had to extend it by a couple of
inches!
rgds,
Thanks for the link guys. Thats a great easy looking mod. I did something similar on my old Golf that worked really well (involved welding in a small spacer but the concept was similar and worked well).
Thanks guys...
IT police wont let me see the link at work. Will look tonight... If its an easy mod hopefully I'll manage.
JoelP, If you U2U me how much you want and if you could post to Aberdeen? Tri, thanks I'll keep yours as a backup...
u2u sent.
