Hi,
Does anybody know if the K reg Sierra 2.0ltr XR4x4 came with a limited slip diff.
The only info I can find is the final drive ratio of 3.9:1 which doesn't equate with the usual LSD ratio of 3.63:1
Thanks,
Dave
Should be an LSD.
2.9ltr came with 3.62.
2.0ltr had 3.9
HTH,
James
Don't all the 4x4 have LSD?
There should be a tag on the diff. The code will tell you the ratio and whether it is an LSD, though from recollection all 4x$ had LSDs
See: http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Diff%20ratios.jpg
Yeah all 4x4s have rear LSD. And yeah the 2 litre is a 3.92.
I'f you're getting a complete car I'd be very interested in the front diff and front propshaft as spares for mine
Liam
Oh and another thing if you're getting a whole 2 litre xr4x4 for a donor - you can flog the 4x4 MT75 and slap on full cossy tax (over 100 squid I
sold one for) as it's identical to the cossie 4x4 box .
Liam
dave j, first dibs on the gearbox (minus cossie tax ,cheers liam!) please, i might have a prop for you if your putting a rover lump in
Sorry guys, I don't have the car, but the LSD is a possibility as it came from that particular model. The ratio threw me as I thought all the
LSD's were 3.63:1
Apologies if I raised your hopes
Thanks for the info.
Dave.
I have a 3.62 LSD that I will happily swap for the 3.9 one that you are looking at!
Guessing you want the 3.62 with your v8.
