Correct Sierra Column???
TimC - 2/5/06 at 03:57 PM
The search for donor parts continues....
would this work with a MK or GTS Panther?
Looks different to other Sierra columns?
Apparently, it's from a Saphire....
Ta
nitram38 - 2/5/06 at 04:17 PM
Your car is missing some wheels!
flak monkey - 2/5/06 at 04:21 PM
Yeah that will be fine. Thats the adjustable column by the looks of it. Makes getting in and out a bit easier apparently.
muzchap - 2/5/06 at 04:24 PM
Yup same column as mine
Just make sure you push it in - to bolt into the column downlink!
Its height adjustable and also pulls towards you or pushes back.
It's definitely better IMHO
TimC - 2/5/06 at 04:25 PM
Cheers David - Always on hand.
As for the barrow - looks no different to a lot of 3-wheelers I've seen!
Cue Major Flaming!
