Anyone know cars whose uprights have their steering arms towards the rear? I think some MR2's do- being mid-engined means its probably easier to
fit the rack behind the front axle. But was just wondering if there was anything a bit more mainstream (i.e. easier to get at the local scrappie!
chris
X1/9's do. And Morris Minors (if you don't mind trunnions)
I'm about to butcher my semi-dissolved X1/9 for a project. There are loads of defunct one's about.
Neil.
mk3 on escorts and fiesta,mondeo are prob fave
Thx guys for the replies
The ford stuff sounds v.interesting. Id checked a sierra but it was front mounted. Should be no probs getting hold of either fiesta, escort or
mondeo
thx again
chris
Agreed - Most of the FWD Ford stuff runs the rack behind the front axle.
Chris
Is there a problem with running the uprights on the wrong sides to get the steering arm in the right place? I know that this could affect castor angle etc. but assuming this can be corrected I cannot think of any reason why this wouldn't work, but I'm not clever on suspension - yet!
If you want some mk1 mr2 uprights with a steering rack, track rod ends, most of the column, etc just give us a shout! Ive got an mr2 on the drive growing mould. It was gonna be my engine donor, ill still keep the engine for a while though.
Andy, yeah you are right- swapping uprights is going to mess up your castor. Put simply- the upper balljoint must be further towards the rear of the
car than the lower bj. (Positive Castor)
As I see it swapping the uprights would make the upper balljoint further FORWARDS creating what I think is known as NEGATIVE castor which is
dangerous. The reason for this is that, at rest, the outside wheel adopts positive camber when turned, which of course becomes much worse when
actually driving the car round a corner!
BTW Des Hammill's book is great for explaining all this suspension stuff. Its quite short which is great if u prefer welding to reading!!
chris
Originally posted by 8smokingbarrels
Andy, yeah you are right- swapping uprights is going to mess up your castor. Put simply- the upper balljoint must be further towards the rear of the car than the lower bj. (Positive Castor)
chris
Originally posted by gazza285
Don't worry about Akermann, Colin Chapman didn't. Most Lotus cars have (had?) parallel steering arms as He though that Akermann with radial tyres was a waste of time.
