Hi
I have a 1992 Ford Sierra 1800cc 5 door manual hatchback. Would the gearbox be a type 9.
Barry
yep
u sure? i think by 1992 they switched to the MT75 one...
89 was the Mk1/Mk2 change over, but typical of Ford, they used the type nines until they ran out!
I would have thought a 92 would have been a MT75.
I believe that reverse is in a different place on the gate but I'm buggered if I can remember which is which!
Chris
type 9 reverse is up left and up ie next to first
mt75 reverse is below position 5 also type 9 has push down to engage rev
mt75 has a lift up bit on the knob
hope it helps
sure the mt75 was only fitted to 2l in 2wd and the 2.9 v6 in 4wd
I have two late K 1.8 sierra's both have type 9's
On the late 2.0's, the type 9 was fitted to the pinto, and the MT75 to the twincam
My h reg 2.0 DOHC donor was MT75. That wa sthe best bit of the car and no use to me
hi all,
as im new to this, can some one tell me, does it make a difference wether you have a mt75 or a type 9, if so what is the difference, and how does
it affect the build
cheers
mark
