has anyone had problems withnitron shocks from gts? i have recently passed sva and thebush rubbershave collapsed so much that the bush tube is bottoming out in the suspension bracket.cant get areply from gts .any sugestions as to what bushes will be better than origonalsthanks.
Can't help, but our Nitron bushes were shafted after only a couple of thousand miles.
Our first MOT is due in a week or so, so I'd be interested in the answer too
Not the first time this has been mentioned:
http://www.locostbuilders.co.uk/viewthread.php?tid=62431
I'd call rally design and see if they make a polybush to fit.
If anyone does find any off the shelf poly's post it up as I am sure we are all in the same boat
Mine collapsed to, changed to polybushes.
Works perfekt now.
I used the polybushes that came with the GTS kit, just corrected the length.
[Edited on 2007/9/18 by mickebo]
