how strong is a 4.8 10mm bolt please
I caclulate it to be 45000N.....But that figure doesnt seeem right...
400N but found this as well.. good luck!
In accordance with BS 3692:2001
The designation system allows the determination of the ultimate and yield/proof strength of the bolt. The designation system is based on two numbers
e.g 8.8 . The first number is the tensile strength of the bolt material (N2 )/100. The second number is = 1/100.(the ratio of the Proof (or Yield )
stress and the Tensile strength expressed as a percentage = 100.[Yield (Proof stress) /Tensile strength] /100
The tensile and proof strength of the steel for a 4.6 bolt is therefore calculated as follows
Tensile strength (Rm) = 4.100 N/mm2 = 400 N/mm2 .... Proof strength (R0,2) = 0,6*400 * 100 /100 = 240 N/mm2
SO... 4.8 = 320N
[Edited on 13/5/08 by coozer]
Hi. It's about half the strength of an 8.8.
See here
The first number is the ultimate tensile strength, in hundreds of Newtons per mm^2. The second number is the percentage (divided by 10) of the
ultimate strength at which the material will yield (permanently deform).
e.g. A 4.8 bolt has an UTS of 400 N/mm^2 and a yield stress of 80% of this - 320 N/mm^2.
To actually work out the strength of the bolt you obviously need to multiply this figure by the cross-sectional area of the bolt in mm^2.
For M10 the minor diameter is about 8.5mm so the area is pi * (8.5/2) * (8.5/2) = 57mm^2 so the yield strength is 57*320 = 18000 N or about 1.8
tonnes.
[Edited on 13/5/08 by matt_claydon]
About as strong as a hard cheese
You have bought something Chinese I think?
They use crappy bolts like that.
Steve.
They use crappy bolts like that.![]()
Steve.
Throw it in the bin and use an 8.8 or better.
Reusing old knackered weak bolts is a mugs game.
Strangely enough a lot of structural steel is held together with 4.8 bolts.
Al.
] And remember that the stronger the bolt, the higher it must be torqued: http://www.cncexpo.com/MetricBoltTorqueNm.aspx
Nick
Funny things bolts, my mate fitted the front discs to his 750cc bike using stainless slot headed machine screws, cos they were shiny and he had some
in a drawer.
Despite all the warnings of impending doom and disaster, they proved reliable for at least 40k miles to my knowledge.
Maybe we all worry a bit too much
Personally never use anything below an 8.8 for anything my life depends on.
Al
