Noise 2db too high. Vin not in a continuous line. No interior mirror. Gearlever to sharp. Fog warning packed up. Rose joint locking nut loose on suspension. Design weight too low at920kg. Front indicator checked at 45degrees not visible. I think this should have passed at 20degrees as mounted low. I also assumed as the indicator can be seen on weel arch this was fine. Mirror I assumed if n/s fitted and passed rear view would be ok his book was slightly different to mine. When corner weighted my car was 670kg his scales said 810kg for a Haynes7.Sierra diff bmw box Alfa v6 alloy engine.plastic seats no screen.seems very heavy for me. Also in the Iva info of my computer it mentions a decel test for lsd equipped vehicles. I told examiner diff fitted(xr4x4) and it was not in his info .he still tested in rollers I am hoping no damage to diff. As a tester myself I was not happy but you don't want to rock the boat at£450 for a couple of hours work. So remedial cost very little. General experience not to bad and tester seemed fair and approachable,and as always could have been worse.
Sorry to hear about your fail. One point concerns me is your design weight. Mine is MX5 based and its ULW is about 1060kg, my Haynes currently weighs
about 500kg (no water fuel bodywork etc at the moment) so I expect it to weigh less than yours finished. 810kg I can understand as all up max but
surely not an ULW? Is that what he was saying?
Ian
Thats flipping heavy for a haynes. My lardy fat arsed Rover V8 tug boat Viento with a full tank and me in it weights 768kg as tested at IVA last month.
I also have two curved decibel killers that might be for sale. U2U me if interested.
Yes his machine is saying all up weight was 810,I think it's over 100kg out. All I have to do is change weight plate to higher and it passes. Allowing 150kg for passengers plate to read 960 obviously the fattest 7 in the UK.
quote:I would make the "designed" weight higher than the minimum allowed by iva, just in case you want to take heavy luggage somewhere. just ensure its within the rating of the tyres and original suspension.
...I told examiner diff fitted(xr4x4) and it was not in his info .he still tested in rollers I am hoping no damage to diff....
