ETB Dials
JeffJeffers - 22/10/13 at 07:28 PM
My winter project is an engine change. As I am using the clocks from my donor bike I have a set of ETB dials I no longer need.
There is 4 gauges speedo, rev counter, water temp and fuel gauge.
The speedo has about 3,000 miles on it.
I will also include the fuel sender and speedo pick up.
I don't have the water temperature sensor but this can be bought from ETB.
I did have to modify one of the gauge brackets to make it fit my dash as you can see in the picture.
I'm after £150 for the lot.
fregis - 22/10/13 at 07:47 PM
speedometer electric or mechanical?
JeffJeffers - 22/10/13 at 07:49 PM
It's electric.
ianm67 - 22/10/13 at 07:50 PM
What size are the speedo and tacho? 80mm or 100mm?
IanM
JeffJeffers - 22/10/13 at 08:49 PM
The speedo and tachometer are both 80mm.
RichB - 23/10/13 at 12:05 PM
Hi
Will the tacho suit a 4cyl engine? If so yes please.
Rich
ianm67 - 23/10/13 at 12:22 PM
Hiya, thanks for the info', I am looking for 100mm units so I'll have to give these a miss.
JeffJeffers - 23/10/13 at 01:15 PM
I used them on my 4cyl 2.0l zetec and the tacho worked fine.
