This is a commercial ad. I've emailed Chris though haven't heard back yet. It was suggested I go ahead and post it then Chris can get a
hold of me as he's available. If you don't want to look until after I've talked to Chris, please back out of this post.
If anyone is building a turbo Hayabusa I have a cast turbo manifold I've developed.
• T3 turbo exhaust manifold for Suzuki Hayabusa motors
• Designed for a bike so the turbo is tucked in tight. It does clear the oil filter
• Smooth equal radius bends
• True merge collector
• Lowest back pressure and best flow possible
• Constructed of 347 Stainless Steel
• Thick main flange/spigot support
• 3mm (.118”) thick tubes
• 15mm thick turbo flange
• Smooth equal radius bends – A smoother shape equals more flow and less back pressure/pressure drop
• True merge collector - All tubes are aimed at the turbo inlet
• Lowest back pressure and best flow possible – pressure and flow go together for less heat and more power
• Investment cast – Consistent shape and quality with NO welds
• Constructed of 347 Stainless Steel – Better strength and better high temp corrosion resistance
• All junctions feature ample filets – More details for the absolute best strength
• Thick main flange/spigot support – Assures a perfect, consistent fit
• 3mm (.118”) thick tubes – Overkill for the strongest available
• 15mm thick turbo flange – extra heavy for the best stability and zero warping
• Cylinder 1 & 4 upper/outer mount holes are slightly over sized to 9mm - Allows for expansion and contraction without breaking studs
• Lower mounting holes are slotted – Allows for easier insertion of mounting bolts
• Turbo mount threads (10 x 1.5) are produced with a thread forming tap – Formed threads are stronger than cut threads
I have posted a few pictures in the Photo Archive.
They're $1,250 USD
Please contact me with any questions or see my site, fabhabit.com
Thank you
Billy
Fab Habit
Salt Lake City, Utah
looking very nice! i hope you get round to selling some. A for effort
Originally posted by Gre3D
looking very nice! i hope you get round to selling some. A for effort![]()
Well that was definitely not 10mins work, looks a really good job!
In my experience a decent designed cast is a far better long term solution 😉
DG
DG
