AIM MXL Digidash
flak monkey - 22/6/07 at 04:34 PM
Look what I have just got my grubby mitts on.
An AIM MXL pro 05 datalogging dash with lots of toys. I need to generate all the cables for it, but thankfully I dont think that will be a problem!
[Edited on 25/6/07 by flak monkey] Rescued attachment DSCF0895.jpg
nitram38 - 22/6/07 at 04:37 PM
You lucky Bas................
flak monkey - 22/6/07 at 04:39 PM
http://www.aimsports.com/products/mxl-pro/features.html
First question, anyone know where I can find 37 and 22 way deutsch connectors?
flak monkey - 22/6/07 at 05:23 PM
Best I can ascertain the connectors are 37 way and 22 way bayonet locking MIL spec affairs.
Had a look on the RS site and needless to say they are a touch pricey, but I am not entirely sure I have the right ones. The pin layouts look the same, but theres Key N and Key A ones, and I dont understand the difference
22 Pin key N
22 pin key A
37 pin key N
37 pin key A
Any ideas?
Confused but excited. - 22/6/07 at 05:37 PM
I think you will find the difference is in the pins. One will have female pins (hollow), as in a flying socket. So that they make a pair of connectors.
flak monkey - 22/6/07 at 07:02 PM
Apparently its to do with the ribs on the plug which make sure you put them in the right way. Mine are N type apparently.
matt.c - 22/6/07 at 08:49 PM
lucky fecker!!! Thats the bo**ocks mate!!!! you dont really need that do you
I want a student loan!!!
[Edited on 22/6/07 by matt.c]
humphfury - 22/6/07 at 09:03 PM
Try www.deutschuk.com for AS Double Density connectors. If the connectors have a red colour band then they are N keyway (the most common).
Humphfury
flak monkey - 22/6/07 at 09:42 PM
Humphfury
Thanks for that, they do have a red colour band, and I have emailed deutsch for some info with the numbers on the connectors. Hopefully they can sort me out with the necessary bits.
No Matt you cant have it . Not even sure when I will get around to swapping them over. When I sort the new dash after SVA looks like a probability if I can get this one programmed and working (I dont have the USB lead a the mo)
bigrich - 22/6/07 at 10:18 PM
thats almost as sexy as the lady in your avatar
humphfury - 23/6/07 at 03:30 PM
Are there are any numbers on the connectors as I might know someone who would be able to identify the mating part.
Humphfury
flak monkey - 23/6/07 at 03:40 PM
Humphfury
Thanks, dont suppose you know where I can get them from?
What I need is a Deutsch AS614-35PN or Souriau 8STA6-14-35PN connector. Have emailed both Deutsch and Souriau in the hope one of them will be able to supply one of the connectors as I cannot find them from either RS or Farnell and I dont know where else to look. The closest I have found is the ones on the RS website but they are size 15 housings and I need size 14.
flak monkey - 25/6/07 at 04:14 PM
Sorted, got put in touch with Servo Interconnect by Deutsch. Now I need to find the money! Mil Spec connectors aint cheap...
humphfury - 25/6/07 at 07:39 PM
Yes, that's the company that my contact suggested.
He also mentioned 2nd mortgage!!!!!!!!
Humphfury
