at donington on the weekend there was a new trader called Kraftwerk tools, its the first time i have heard of them. Apparently they are Swiss made
and well established as a quality tool brand like snapon etc in the rest of europe. they looked pretty well made and have a lifetime warranty even
on the moving parts.
got chatting to them and they loaned us some tools we liked the look of to have a play with over the weekend, when were doing the bertini
conversion.
any way. to get to the point one of the bits they lent us were a set of open ended ratchet spanners. I didn't even know such a thing existed!
I have closed ring ratchet spanners but these are something else! all the times I couldn't get a ring ratchet spanner on a bolt! and they have
gone and solved it!
Is it just me or do they look like they might round off rusty nuts quite quickly?
Clever idea but have to agree with slimy38 if you were to tackle a siezed nut youd round it off. Wouldnt mind a go and being proven wrong.
Seems a bit pointless to me, why not just put a socket in the whole with a bar ??
what if the hole is not there or smaller. they have it so you can see how it works.
don't think they are meant for undoing seized/very tight nuts.
i can think of several jobs on the car where they would make things easier, tighten most of the way with one then do the final nip up with a normal
spanner.
How much are they?
Draper do them as well
Originally posted by jollygreengiant
Firstly, they are NOT designed to "break" a nut. So they would not "round " off a nut. Further, IF a nut was 'that' tight to spin off the thread that it 'rounded' the nut then surely, before you re-fitted, you would clean the bolt/stud and then fit a NEW nut.
As much use as a toilet seat hinge in a convent.
When was the last time anybody here used an open ended spanner except on a trackrod end?
See various
http://www.workshopping.co.uk/shop.php?search=flexible+head&x=0&y=0&sec=search
Andi
Originally posted by GreigM
....I have a set, find them not very useful - can't get any meaningful torque applied....I find that if the bolt is loose enough to work with these, then its loose enough for my fingers to do a better job.
Would have useful to work on this bugger :-
My Uncle recently did a job on his 1996 Mk3 Polo where he had to replace to power steering fluid transfer pipes on the steering rack. One of the banjo bolts was inclined backwards towards the subframe and was a pig to get out and replace. Only a very small arc of spanner swing was possible and although he was able to get a ring spanner over the original shallow headed banjo bolt, he chose to replace it with a banjo bolt with a normal head depth because of the risk of rounding the original bolt’s head which was deteriorated due to corrosion. With a normal depth head banjo bolt fitted, a ring spanner would not fit over the head of the new banjo bolt because of insufficient clearance between it and the subframe. My uncle imagined and then searched for (but did not find at the time) an open ended ratchet spanner that would have been ideal for this job. He was delighted the other day when I informed that they did actually exist even though by then he had completed the job with a conventional open ended spanner. So, there are definitely jobs where there is insufficient clearance to get a ring spanner (or ratcheting ring spanner) over the head of a bolt or nut and where restricted spanner swing calls for a ratchet solution. They are expensive but when you need them you really need them!
^^ but if you can do it with a normal open ended spanner then you didn't really need the fancy ratchet one
also you can presumably only use them one way round for the ratchet bit to function meaning you need space for about 60° of arc on the spanner to make
it work (ie. to get from one flat on the nut/bolt to the next)
with a normal open end spanner its the same except that the end is angled so you can flip it over every part turn of the bolt - so you can work with
only space for a ~30° arc - although it takes ages this way its still means you get into tighter spaces with a bog standard open end spanner !
(this is how open end spanners achieve the same ranges of movement that bi-hex rings and sockets can)
[Edited on 5/9/2014 by mcerd1]
