Poly Bushes
Cadburys Man - 10/10/13 at 09:37 PM
Would these poly bushes fit my Stuart Taylor Locosaki??
Haynes Roadster Locost Front &' Rear Wishbone Bushes in Polyurethane - Sale
Daz.
Bare - 11/10/13 at 02:59 AM
Might jusat.. But you do realise that Poly bushes bear a striking resemblance to Similar shaped Oak pieces.
As in every bit as compliant (yes it's been done) Be careful in what you wish for.. It may not please.
renetom - 11/10/13 at 07:50 AM
Hi
They give you all the dims
Check out yours, its easy enough.
good luck.
TimEllershaw - 11/10/13 at 08:02 AM
I'm currently replacing wishbone bushes on my car, so have done quite a bit of reading and researching. This is quite interesting :
Wishbone Bushes
Minicooper - 11/10/13 at 09:38 AM
I don't know if these will fit either, but the bush is rated at 80 shore which means they are soft in comparison to the rock hard 90 shore which is the normal material. I have some in the garage and they are quite flexable
[Edited on 11/10/13 by Minicooper]
