Building a wooden workbench
computid - 17/3/23 at 10:57 AM
Hi All,
Thought I'd ask the collectives advice twice in one week!
I'm looking to build a decent, sturdy, garage workbench for a multitude of purposes. I want to be able to use it for everything from Carbon Fibre manufacture to metal work and engine rebuilds, so it needs to be strong, big (ish - 1200x1000x1000), and sturdy with a hard wearing top. I also don't want to spend a ton of cash, so my budget is around £200 total.
My plan is to build this using just Wickes Sawn Kiln Dried C16 Timber - 45 x 145. I'm hoping I can make both the frame and the top from this wood.
This is the design I've come up with:
Now, it's important to note that I've never built anything like this before, and wood work is not my strong suit, so my knowledge may be somewhat lacking and as such please excuse any silly questions!
The frame I'm fairly confident with, but it's the top that's causing me some questions. My plan is to paint some epoxy on one edge of the top planks, butt the planks hard up against each other on the top, and screw them down to the frame with deep countersunk screws. Let the epoxy harden off, fill the screw holes with wood filler, and then sand the top down flat. Hopefully this will provide me with a really strong and flat top. Then I want to treat the surface with something, ideally to stop resin from Fibreglass or Carbon sticking to it in future. I was thinking of varnishing it with polyurethane varnish as most resin doesn't stick to it.
For the shelf below I'm just going to use MDF or something as it doesn't need to be particularly strong.
As ever, I throw myself over to the LCB collective for your judgement and thoughts! Any input or worked examples most welcome!
Many thanks!
roadrunner - 17/3/23 at 12:07 PM
Use PU glue. you can get different curing speeds from 5 mins to 30 mins. Glue all your joints as you have no triangulation for strength.
Can you not use a decent plyboard for the top rather than gluing timber together. Marine ply would be best. Then I would cover with a sheet of ally, Maybe temporary screw it down so can be removed for different job types.
cliftyhanger - 17/3/23 at 01:24 PM
I am not a pro by any means, but 6x2 (sorry, thats just the way I work) doubled up for legs is huge. If you want to use a L shaped leg, it could be 4x1 and that would still be hugely strong. Likewise the frame around the bottom. For a really solid top 6x2 is not a bad thing, or even scaffold planks. Ideally sash cramps while gluing together, beg/borrow/steal some. (buy from Toolstation, then return?? naughty, but if you take care nobody would know)
I would want some diagnol bracing in there too. Even if just in the corners.
snapper - 17/3/23 at 03:34 PM
I have seen and intend to use myself 19mm ply from B&Q for the top of my benches, previously I have used 16mm floor board material which is ok but I want something I can slap a gearbox or an engine on it.
James - 17/3/23 at 07:20 PM
Based on your description, you're looking for flexibility more than anything else.
I would be tempted to make it from square/rectangle metal tube so that you have less volume of material to get in the way of different projects.
I inherited a steel tube workbench from work that I cut down as my garage is quite small and re-welded and painted. It's mainly 25mmx50mm tubing and it's *incredibly* strong and stiff. conveniently, it doesn't even have front legs. The front legs have been moved back to about 150mm in front of the rear legs. This means you don't have a leg getting in the way of stuff.
I'll try and get a photo for you.
James
nick205 - 17/3/23 at 07:30 PM
James
A metal work bench (with metal top) is ace for welding on.
JoelP - 17/3/23 at 08:32 PM
I'd agree those timbers are excessively large. That would support more tonnes than it would ever see. In the past, I've used back to back kitchen units, with scrap worktop on it. That gives you 1200 deep and however long you want, excellent storage and perfectly level. Only thing to consider is lateral loads on the legs. Replace them with stout 7cm ones rather than standard 15cm ones.
nick205 - 18/3/23 at 03:45 AM
Done this before in my garage. Kitchen worktop will take quite some abuse and as said is well flat. Old kitchen being removed and reused from my house at the time.
MikeR - 18/3/23 at 06:33 AM
I did the same design but used 2x4 as it was really available. The top was a reclaimed kitchen work surface.
(Reclaimed out of a skip, I did ask the owner & yes I drove home with the boot open as it was so long & yes my wife wasnt happy as we'd only recently moved into the house and still trying to seem "normal"
Think long and hard about the height. I made mine a little too high (perhaps 2 or 3" but I have a bad back and didn't want to be bending down. Also think about the depth, my kitchen work surface was very deep and I struggle to reach the back. Finally, think about a lip at the back to stop stuff falling behind. I extended the rear legs up, then used them to hold a plywood back board. This allowed me to have shelves mounted of it, stopped stuff falling down the back and acted as triangulation.
Big T - 18/3/23 at 10:07 AM
This is why I love it on here, modelled work benches posted for input, it’s great!
I’m currently planning to have a move around in my very leaky, knackered garage. As such I want something that will be pretty resilient. I collected some sheet pallets, they consist of about 4 to 5 lengths at 3000mm of 2”x4” timbers and a few larger cross bearers at around 1500 which are ideal for the legs. I’ll make a frame up much like a build table, throw a load of cross braces in there with some laser cut sections for triangulation and support, Chuck a bit of ply on the top and then cap that with some stainless, I made one a few years ago and capped it with a bit of mild steel and that was a terrible idea!
Reused kitchen is a great idea, however the water my garage lets in the whole thing would fall apart.
[Edited on 18/3/23 by Big T]
cliftyhanger - 18/3/23 at 12:53 PM
As a temp engine build table, I am using a bit of12mm ply, 1200x600ish. Made a support frame from 3x1 set 4" in from the edge, some 6x6x2 blocks in the corners to attach the frame to and then 4 ikea table legs .
That was originally made as a table extension for Christmas a few years ago, but now kept in the garage for occasional use. Holds a hefty (dolomite sprint) 4 cylinder engine (150kg) no probs, though I am aware of not putting large lateral loads on it. Bulit 3 engines on it, take legs off when finished and store it against a wall.
People often seriously over engineer this stuff, it really isn't necessary.
ReMan - 18/3/23 at 01:27 PM
TBH unless your used to wood, its you'll either spend a ton on wood or the tools to work it and it will still be a wooden bench.
IU'd be looking for something like this
https://www.ebay.co.uk/itm/275688167241?hash=item40304b9749:g:fz8AAOSw9RZj67Lz&amdata=enc%3AAQAHAAAAwMQsjMyKtZay%2BaYpkrdxBSDk2hFWpYlOFEufez8mFO84 0yWnuhktWX3tqXk%2BmHgRnDdjaTAJN8qKo0RUznEnus3VW2A6oo1YSylZIcetgJDGP4RD9maCJbFWgn2LEneJaqEVBE3AmZzr%2FaaQ%2BBN5oNh3EnoNzlr2K%2BuHfEpZW0i21htDVImPQeSET3 24XFvZcnnwzyuEHUJeciAQREzHwqJjEUObiYfw7na2NKT2oxvCLH603s3sEiMNqi1yvBlT5g%3D%3D%7Ctkp%3ABk9SR4iDwM7eYQ
[Edited on 18/3/23 by ReMan]
David Jenkins - 18/3/23 at 01:40 PM
Triangulation would make a huge difference - 1 diagonal at the back, and 1 on each side.
designer - 19/3/23 at 12:32 PM
3 x 3 is large enough for bench legs
harmchar - 19/3/23 at 05:47 PM
I would also suggest using ex-kitchen work top as the top surface. Scratch proof, can weld without burning, doesn’t matter if you spill paint or fibreglass or body filler on it. Will be almost perfect flat compared to ply.
David Jenkins - 19/3/23 at 06:17 PM
I tacked a sheet of hardboard over the plywood top of my workbench about 20 years ago - still there!
coyoteboy - 20/3/23 at 09:17 AM
Personally, as a metal person not a wood person, I would say those timbers look fine. I've destroyed so many wobbly wooden tables. I now have a 2mx1m workbench made with 150x40x3 steels welded with cross bracing at the back and corners and a 30mm replaceable ply top which is the only one I haven't destroyed.
So to me, your original design just needed some cross bracing and a metal skin on the top surface unless you keep it as freely replaceable.
nick205 - 20/3/23 at 01:42 PM
Unless you need a metal worktop (for welding) then a wood worktop should do you fine. I've built one for myself and one for a mate with kitchen laminate worktop. It's cheap from Wickes and it's also good and flat too. If you screw it on from below it'll be easy enough to remove and replace if you damage it.
[Edited on 20/3/23 by nick205]
nick205 - 20/3/23 at 01:44 PM
Also, secure the bench to the wall to stop it tipping on you or moving aroud.
HowardB - 20/3/23 at 04:24 PM
my 12' bench was a pallet that a machine tool arrived on - it is massive and huge over kill! The smaller work bench was scavenged from a closing lab 40 years ago.
well looked after it will out last me
computid - 23/3/23 at 12:49 PM
Okay, so, I cheated. I found this steel Bench Master workbench on Facebook marketplace for £125 just down the road from me and snapped it up. It weighs more than a 7 chassis so I don't think I'm going to be breaking it soon!
trextr7monkey - 25/3/23 at 12:58 AM
I’m a retired DT teacher well capable of making a decent bench but with the price of wood it’s not the greatest idea if you are looking for a multi purpose bench rather than some thing for engaging in fine wood work. I picked up 3 traditional joiners benches from a training centre for £90. Very heavy, 2 wood work quick release vices on each one all for £90. Gave one to a mate and sold another for £120. This provided a free bench to modify as appropriate. If you are not into wood work I would recommend this approach and you can get on with your other more interesting hobbies!
If you decide to press on with making your own this topic has been done to death on the UKworkshop site with lots of sound advice and access to designs
