as above... Am expecting the correct answer from Flak Monkey any second now.....
Thanks!
Ford recommend:
5w-30
For a highly stressed engine I would recommend (going by what I have read and experienced) going for an oil with the next viscosity up, so 5w-40
should be the one to have. This means under the harsher conditions the oil film will more likely be retained.
A bit of research also suggests that 5w-40 is one of the alternatives recommended by ford for the duratec anyway. That specifically being Formula Ford
S Synthetic
Fully synthetic of course.
[Edited on 3/11/09 by flak monkey]
haha - even quicker than I was expecting!
much appreciated tho
cheers mate
here's what i've found in TIS
http://lh3.ggpht.com/_O3xyB4d07ko/SvB-3N8GOEI/AAAAAAAACCs/3O3UuJBdvw8/s800/oil.JPG
