What size bolt on type 9 oil filler
steve8274 - 8/6/13 at 08:35 AM
Following on previous post about type 9 oil for gearbox, the oil has arrived. Before I set to doing the job and struggling underneath, does anyone know the size of bolt or Allen key required. Just to make sure I have that size before I start job
Blackhole - 8/6/13 at 08:53 AM
You'll need a 10mm Allen key wrench
rusty nuts - 8/6/13 at 08:55 AM
And a length of pipe to use as an extension, it will be tight
steve8274 - 8/6/13 at 09:02 AM
Great thanks. Was considering making a hole in side tunnel to gain access then cover over after. Not sure if feasible tho.
rusty nuts - 8/6/13 at 10:03 AM
That's what I've done, the biggest problem is finding a large grommet
jacko - 9/6/13 at 02:32 PM
And me its the easiest way to do it
Jacko
