Evening all,
I have recently pulled the engine out of my F27 to allow me to change the rear crank seal as it was leaking.
Whilst I had the engine out I fitted an oil temp gauge and oil pressure gauge and also tidied up some of the wiring.
now I have the car back together, the damn thing won't start!
It is cranking, but coughs and splutters, occasionally catching but immediately cuts out.
Any ideas?
I have tried another set of plugs that I had, but still the same.
Could this be an electrical fault as opposed to mechanical?
any pointers would be massively appreciated as I need the car working to be sold soon!
Thanks,
Liam
Id start by checking out the wiring you tidied up..... that would seem the major change.
As above
Re trace your steps, It might just be something simple that you'll kick yourself for afterwards
Then report back if no joy...
How long since it was last running?
Low on petrol or stale.
Injection or carbs? jets may have got a bit of dirt in them.
Or as previously stated. Important wire not connected or bad connection.
Does it run at all when you release the key from the start position?
If not, you may have the ecu/ignition cct powered from the wrong ignition switch connection.
I would check / replace the fuel and possibly the filters next.
Sounds like ignition and your dropping a coil / two cylinders.
When it fires feel the manifold to see if any are cold.
Dumb question: are you sure that you put the ignition leads back on the correct plugs?
Many years ago, when I first put my xflow back together, I got 1 pair of leads crossed - it managed to start, but coughed, spluttered and backfired
and wouldn't rev at all (unsurprisingly).
Many years ago, when I first put my xflow back together, I got 1 pair of leads crossed - it managed to start, but coughed, spluttered and backfired and wouldn't rev at all (unsurprisingly).
they are all different lengths at the cylinder end, but not at the coil end - ask me how I know!
It was a really easy mistake I made, and a lot of head scratching later I spotted the mistake Starts first time now
the fault finding I did involved checking for fuel, return line, listening to the injectors fire,. checking the sensors to the ecu etc.
is it on the original ECU? If an after-market one can you plug it into a PC and look at the sensors?
hth
I've spent a little while looking over the car again today.
I've found a blown fuse, which I'm hoping is the cause of the car not starting properly.
However, when replacing the fuse, it keeps blowing!
I'm no auto electrician, and the wiring on this car is a bit confusing. If I was planning on keeping the car it would definitely be getting
stripped out and completely replaced!
I don't know where to start with this, are there any electrical savvy locost builders near Chippenham that want to come and have a look for a
beer or three?
