Xflow oil pump variants
GaryM - 8/6/23 at 08:13 AM
I’m considering adding an oil cooler to my 1600GT Xflow.
Currently the shortest oil filter only just clears the bottom chassis rail so there is no room to add a sandwich takeoff plate.
I read recently that there is a variant of the Ford oil pump (make for Capris) that mounts the oil filter at an angle rather than straight down. This might give me the extra clearance I need.
Does anyone know if these are still available?
Gary
nick205 - 8/6/23 at 10:39 AM
No idea of the part or if it's still available.
Someone like https://www.burtonpower.com/ should be able to advise you on what's available for Ford engines. Quite possibly supply the part as well.
Mr Whippy - 8/6/23 at 12:15 PM
sounds like a remote oil filter kit would work, would allow you to fit a nice big filter and have extra oil in the hoses plus locate the filter in a easy location for access.
