I'm going to overhaul the 2.0l Pinto engine that I have. Can anyone recomend a good engineering company near Warwick that can carry out work like
honing and balancing etc..?
Try Chesmans in Coventry, They do a lot of performance machining and ballancing.
Steve.
I WOULD JUST BUY A ZETEC .
it would be cheaper in the short run and long run .
i just got a quote to rebore an xflow to 1700cc and it was £400 from one company and £480 from another
Was that for a rebore to 1700 or rebore and build the whole engine for that money? Rebores round here were £25 a bore last time I had one done.
For a rebore expect to pay around £60+Vat then you will need oversize pistons and rings. Probably worth going to a 2.1 overbore if your block will
take it. Keep an eye out on ebay for a set of 2.25mm oversize pistons and conrods to save a serious amount of cash.
For dynamic balancing not many engine companies have the gear to do it, and it might need to be sent off. I never got around to getting mine balanced
in its current state of tune. Unless you plan on revving to over 7000rpm regularly i wouldnt bother, though it does make the engine run nicer!
If your block just needs honing you can do it yourself.
Check out Vulcan enginering they specialise in Ford engines , you may find an exchange bottom end might be cheaper
try http://www.scholarengines.co.uk/
Thanks everyone.
I'm only looking to do the minimum to this engine to get it through SVA. I just wanted to make sure it was tight, had good compression and
didn't burn oil.
Suggestions are welcome?
Put it in, get it running and find out what it's like . You never know you may be lucky and it's not a huge amount of work .
In which case does it actually need doing? If it's just a for now jobbie, why not just paint it, change the oil and slap it in!
I used this company for my cylinder head preparation. They were quite helpful and reasonably priced. They are near Oxford.
http://www.fjpayne.com/
Originally posted by flying_coffin
I'm going to overhaul the 2.0l Pinto engine that I have. Can anyone recomend a good engineering company near Warwick that can carry out work like honing and balancing etc..?
sounds interesting, mail me with a figure that you are thinking about ?
