What is the diameter of the T9 input splines and sleeve?
1"- 23 splines, not sure about the sleeve dia, why do you ask??
I want to use a concentric slave clutch on a toyota gearbox. I have managed to find out which Mondeo clutch fits on the T9 so I need to know if the dia's are the same. My gearbox is a 21R or W55 I think.
Oh me as well, I have a W58 Toyota box I'm converting to fit my new 170ST engine...
FWD box split and use the front bit as a bell housing..
My Toyota box shaft is much bigger.. I'll measure them tomorrow and hopefully post some pictures.. hic!
why not use a saab release cylinder, they are cheaper!
Also, with a concentric release mech, you don't need the sleeve anymore so you can just get rid of it, that's what i did
