Author: Subject: sierra steering column
gavin174
posted on 17/8/10 at 07:37 PM Reply With Quote
Hi all
I have bought a sierra adjustable steering column off ebay...
all well and good..
it was delivered today, well wrapped.
now to the problem.
the seller has pushed the triangulated/ collapsable bit up into the main column to make it shorter for postage.
will I be able to pull it back out or is the column throw away .
thanks Gavin
RichardK
posted on 17/8/10 at 07:42 PM Reply With Quote
Nah, it'll be ok, go and give a big tug mate, won't come all the way out.
Rich
Gallery updated 11/01/2011
adithorp
posted on 17/8/10 at 07:59 PM Reply With Quote
Yes, it'll pull back out no problem.
adrian
http://jpsc.org.uk/forum/
gavin174
posted on 17/8/10 at 08:02 PM Reply With Quote
thanks for your quick replies..
didnt want to leave positive feedback if it was no good.
Thanks Gavin
big_wasa
posted on 17/8/10 at 08:18 PM Reply With Quote
Yeh it will move if he has left enough to pull on.
procomp
posted on 17/8/10 at 08:54 PM Reply With Quote
Hi
Errr not necessarily correct. It will depend if the secondary bush inside the column has bees pushed up with the inner shaft. It is not captivated and can come loose leaving the inner shaft only supported by the end bush. That's no good as it allows far to much play on the inner shaft.
All you can do is pull the inner shaft back out to the desired length and pray that the secondary bush is still in place.
Cheers Matt
gavin174
posted on 17/8/10 at 09:02 PM Reply With Quote
thanks for that Matt!!!
trust me to be premature, just left him good feedback.
will have to wait to tomorrow to see what happens when i pull it out.
thanks
for all your replies
procomp
posted on 17/8/10 at 09:37 PM Reply With Quote
Hi
On the race cars if this happens we just bolt through the inner and outer shafts to lock them up. Obviously no good if you require the collapsibility of the inner section.
Hope all is ok with the bush.
Cheers Matt
