thenorthface
| posted on 14/9/11 at 11:08 AM |
Sierra master cylinder rod ?
Just got my sierra master cylinder off eBay but there is no thread inside to attach some stud bar for the brake pedal ? How do u attach the brake
pedal to them ?
Ben_Copeland
| posted on 14/9/11 at 11:46 AM |
Did it not come with a push rod attached? Sounds a bit suspicious. Has it got any internal parts inside it???
It might be the plunger is just pushed in. Remove the rubber and check.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
ReMan
| posted on 14/9/11 at 12:23 PM |
If you meean inside the piston, there is no thread, just an empty hole with a rounded bottom
The rod end just rests in there. The held end is with a clevis onto your brake pedal
www.plusnine.co.uk
Bluemoon
| posted on 14/9/11 at 12:36 PM |
Ditto, made my own push rod from HT M8 bolt, rounded off end in bench grinder..
thenorthface
| posted on 14/9/11 at 01:36 PM |
Is the m8 bolt ok to rattle around in the tube ?
lotusmadandy
| posted on 14/9/11 at 01:59 PM |
I also made mine from an M8 HT bolt and a clevis that mounts to
the break pedal.It wont rattle around if you adjust all of
the free play out.
thenorthface
| posted on 14/9/11 at 02:42 PM |
Cheers for that , where did u get the Clevis from ?
