Author: Subject: Seatbelt parts ok for IVA
Slimy38
posted on 4/8/13 at 02:07 PM Reply With Quote
Here is the seatbelt as it's been removed from the donor;
Donor seatbelt
Donor seatbelt
Is it ok to be reused for IVA? Obviously it needs a good scrub up. The upper mounting has a long bolt through the metalwork pictured, can all that be reused?
Does anyone know what the bit of wiring is for though? I've not seen wiring on this side of a seatbelt, only on the catch side where it was for a pretensioner.
big_wasa
posted on 4/8/13 at 03:43 PM Reply With Quote
If the real is not mounted at exactly the same angle as the donor it wont work. four point harnesses are not every ones cup of tea but I really would think about a set for iva. Tried and tested.
Slimy38
posted on 4/8/13 at 04:29 PM Reply With Quote
Yeah I saw that, there is a 'float' type device in the ratchet mechanism that only works when it's fully upright. The fixings are at the right angle though so they should mount quite easily.
