Author: Subject: IRS Donors?
erikn
posted on 18/11/04 at 08:12 PM Reply With Quote
IRS Donors?
Where can i find a proper IRS?
posted on 18/11/04 at 08:47 PM Reply With Quote
i believe some kit cars have true IRS, maybe use one of these as a donor...
seriously though, what do you mean by proper IRS? you almost certainly wont find a donor that you can simply bolt it off and bolt it onto the kit. most people who use IRS have made top and bottom bones, and a hub carrier, and use sierra parts to finish it off.
Tralfaz
posted on 18/11/04 at 10:48 PM Reply With Quote
Couple builders have used the entire rear sub-assembly from the MX-5.
T
posted on 19/11/04 at 10:22 AM Reply With Quote
Some Tiger cars and Robin Hood cars use the complete rear subframe/diff/driveshatf/trailing arm assembly from the Sierra. Even then I believe you have to modify the suspension pick-up points and method to use coilover shockabsorbers.
You could have a look at the book "How to build a Tiger Avon" to get an idea of how to fabricate an IRS set-up for use with Sierra components.
HTH
Nick
Mark Allanson
posted on 19/11/04 at 07:29 PM Reply With Quote
"You could have a look at the book "How to build a Tiger Avon" to get an idea of how to fabricate an IRS set-up for use with Sierra components. "
look at it, see the shortfalls and design something better - it would not be difficult!
erikn
posted on 20/11/04 at 10:34 AM Reply With Quote
ok
ok, thanks for your help.
bob
posted on 20/11/04 at 02:45 PM Reply With Quote
I know the 3 series BMW IRS has been adapted for use on triumph stags,not sure if its too awkward for kit building.
The sierra rear end is a bit of a mess if used in its entirety,i'm sure this is why upper and lower wishbones are used along with bracketing on the chassis for the diff,keeps the weight down too.
chrisf
posted on 24/11/04 at 02:25 PM Reply With Quote
I used the MX-5 as a donor, as did Bob C. Have a look at his archives for a good example.
My work can be seen here. Exactly the same as Bob Cs but with inboard dampers. The bits are perfect for a locost and are very light.
