Slimy38
| posted on 10/5/15 at 02:18 PM |
Brake discs for electrolysis?
Just before I throw out an old set of brake discs, it did occur to me that they are solid iron. So can they be used for electrolysis as the
sacrificial element?
Angel Acevedo
| posted on 10/5/15 at 04:13 PM |
They may be used but I thin they would be awkward to use.
Several smaller pieces is better
IMHO...
| posted on 10/5/15 at 05:07 PM |
Good idea batman, wire up parralel with one each side of the tub/bucket...
Thanks, I'm going to try t!
MikeR
| posted on 10/5/15 at 07:02 PM |
Or bottom of the tub with a draining board plastic mat on top of to give a small gap to the item being cleaned perhaps?
Slimy38
| posted on 10/5/15 at 07:12 PM |
Yep, this was my first thought, large surface area either side of the piece. I believe that while the solution does react all over, there is still a
'line of sight' aspect to the rust removal. So one either side makes sense.
And I can't imagine them wearing out as quick as rebar.
loggyboy
| posted on 10/5/15 at 08:07 PM |
Used a brake disc for my last session. Was v good. Vented helps with surface area also.
Mistral Motorsport
Irony
| posted on 10/5/15 at 09:08 PM |
All round the item works best. I used some iron bar and bent it in a large coil around the object.
Mark100
| posted on 10/5/15 at 10:10 PM |
use graphite rods it cleaner works better to
| posted on 11/5/15 at 10:49 AM |
BUT, where can you get them???
MikeRJ
| posted on 11/5/15 at 03:05 PM |
Readily available on eBay, though not overly cheap.
HowardB
| posted on 11/5/15 at 03:12 PM |
didn't you used to be able to get them from breaking open the blue eveready zinc-carbon batteries? I am sure that I remember doing that,.. D
cells
good luck
Howard
Slimy38
| posted on 11/5/15 at 03:22 PM |
I can find two sources, the best option are graphite gouging electrodes but it seems difficult to get the pure carbon ones rather than the copper
coated ones. And they're not cheap.
The other source is stirring sticks for smelting, although these seem to be pretty much pencils without the wood!
| posted on 11/5/15 at 03:52 PM |
Ive just wired two brake discs together and switched it on, we'll see how it gets on
Angel Acevedo
| posted on 11/5/15 at 07:44 PM |
Never thought of these.
Mechanical pencil leads??
