bi22le
posted on 3/10/23 at 10:51 PM |
I need new front discs!! I can't find the right ones
After doing brands GP I was putting the car on the trailer, strapping it down and spotted my discs were cracked!!!
So Im pretty sure I have identified them as Cortina mk 3 / escort mk 2. Something like this
https://www.burtonpower.com/brake-discs-f-cortina-mk3-mk4-mk5-escort-mk2-rs-pair-di822751.html
Problem is that the pads were slightly of the edge and were touching each other.
I would like bigger than 247mm. Are the solid Sierra rear brake the same? The offset looks good and they are 257mm
Please read my ring story:
Minicooper
posted on 4/10/23 at 02:30 AM |
Hello,
I don't know about the sierra disc, but Rally Design do a 265mm solid disc for cortina based kit cars, a quick phone call will confirm fitment
for you
This one brake disc kit: https://www.rallydesign.co.uk/product_info.php?products_id=10507, just confirming fitment
Here are the available 265mm discs solid discs to suit
Plain disc: https://www.rallydesign.co.uk/product_info.php?products_id=23730
Grooved disc: https://www.rallydesign.co.uk/product_info.php?products_id=23731
Drilled and grooved disc: https://www.rallydesign.co.uk/product_info.php?products_id=23956
gremlin1234
posted on 4/10/23 at 11:19 AM |
you can download the ferodo catalogues which have diagrams and dimensions of pads and disks. and cross references
BRAKE PADS, DISCS, SHOES AND ACCESSORIES 2014-2015 - APPLICATIONS
DOWNLOAD PDF
https://www.ferodo.com/support/light-vehicles/catalogues.html
[Edited on 4-10-2023 by gremlin1234]
adithorp
posted on 4/10/23 at 01:52 PM |
Aren't the Cortina discs bolted to the back of the hub? The Seirra ones go over the wheel studs against the flange.
robocog
posted on 4/10/23 at 03:16 PM |
Brakes International has good data
I am running with Sierra solids with KA/Fiesta calipers
Unfortunately they are only a 240 diameter, so not what you are after
Take a gander on their site though, you may find what you need...
https://brakeparts.co.uk/shop/Ford/Sierra/82-86/Sierra%201.3%20&%201.6%20OHC%20Models/Front%20-%20Brake%20Discs%20and%20Drums/BDS4375
adithorp
posted on 4/10/23 at 06:35 PM |
But not on Cortina hubs where the disc bolts to the back of the hub.
obfripper
posted on 5/10/23 at 07:03 AM |
The rally design discs are modified e30 bmw solid front discs, their website describes them as 265mm, in reality they are 260mm and it does mention it
somewhere in the details.
They are reasonably priced though and off the shelf so might be the simplest answer.
There are also a few peugeot/citroen front discs that are modifiable to fit inboard on the escort/capri hubs if you have the engineering equipment to
do such, I'm not 100% sure there are any solid discs amongst those though.
These are vented versions, but you can see the difference.
Dave
bi22le
posted on 5/10/23 at 02:09 PM |
This is correct, the cortina discs have a tiny offset, about 1/2" because they bolt to the back of the hub
Minicooper
posted on 5/10/23 at 06:31 PM |
I have a set of the cortina fitment 265mm solid discs here which I can measure accurately for you including thicknesses, offsets. etc, whatever you
need. Let me know
[Edited on 5/10/23 by Minicooper]
bi22le
posted on 5/10/23 at 07:19 PM |
Are they for sale 🤣
I have old ones to measure. I just wanted slightly bigger than 147mm. Ideally 155mm to stop the pads hanging off the edges.
Minicooper
posted on 5/10/23 at 09:10 PM |
Not for sale, just trying to help out
Dingz
posted on 7/10/23 at 04:33 PM |
1.3 Sierra fronts are only 240mm
went on and on.
bi22le
posted on 8/10/23 at 10:01 PM |
Update. . . I just bought some non grooved or drilled versions from Burton power. Unless I customise them I can't get cortina fitments which are
around 155mm. They don't exist. Annoying as these Raceleda uprights and calipers create a tiny over hang for the pads.
Grrrr
obfripper
posted on 9/10/23 at 08:34 AM |
Are the raceleda calipers you have radial mount? If they are, you could get the overhang depth machined off the brackets, and they would still be
adjustable to bigger discs with spacers.
Dave
Schrodinger
posted on 9/10/23 at 09:15 AM |
You could try Tiger Racing they have some cortina fit discs on their site and might be able to help with the size you need.
01945461423
Keith
Aviemore
