adders
posted on 26/3/07 at 09:37 PM |
diffs
will a escort cosworth diff fit mk indy and will it have lsd?
[Edited on 27/3/07 by adders]
Blakey_boy
posted on 27/3/07 at 07:20 PM |
Should do as its an IRS same as the sierra cossies. The Escort cossie was a rear whell drive as it had the same floorpan as the sierra cossie
Blakey_boy
posted on 27/3/07 at 07:21 PM |
If you are unsure about it ask Burton's in Ilford Essex thats where I get most of the info i want when I need it
Liam
posted on 27/3/07 at 07:54 PM |
Escort Cossie is 4 wheel drive and has the same bits as the sierra cossie 4x4 and the XR4x4 too. So it's a 3.62 7" LSD.
Hope that helps...
Liam
adders
posted on 27/3/07 at 08:37 PM |
escort cosworth diffs
cheers lads, wot would you except to pay for one?
Blakey_boy
posted on 27/3/07 at 09:46 PM |
Recon units start at aroung 300 up to 1100 with an ATB unstalled s/h around 100 upwards from a scrappie but, I COULD BE WRONG
adders
posted on 28/3/07 at 07:12 PM |
diffs
cheers for that.
