rabiddog
posted on 22/10/03 at 01:04 PM |
Lada donors
Anyone any experience of using a lada as a donor?
Seen a company in links make a kit for it
And on the locost car club site it mentions ladas have the same dimension axles as mk2 escorts is this true?
Craig
Poolegan
posted on 22/10/03 at 02:47 PM |
Why would you want to use a Lada as a donor? A crap car must make a crap kit. Parts are likely to become difficult to find and what about tuning?
The thought of a juiced up Lada is scary - unless you do it the Lotus way as on top gear
Mark Allanson
posted on 22/10/03 at 06:47 PM |
The Lada was basically a Fiat 124 which was a great car in its day, 5 Speed box, rear discs, option of a twin cam motor - all when its nearest Ford
competition was the Anglia.
Good points - You can fit the Fiat twin cam without any problems (possibly even the croma range), easily available parts from Fiat or motor
factors.
Bad points - Bad quality castings and fixings, if you undo a bolt you will end up with the sheared head in your socket!
stephen_gusterson
posted on 22/10/03 at 09:22 PM |
From someone thats building a robin hood
atb
steve
rabiddog
posted on 22/10/03 at 11:44 PM |
I dont really want to use a lada just got one that belonged to my grandad cluttering my field was more curious about the axle really
Craig
posted on 23/10/03 at 08:18 AM |
measure it and see i guess. depends on the car you build if it will look right. and maybe check the ratio as well.
