Author: Subject: Rivets and spacing
speedyxjs
posted on 7/5/09 at 12:32 PM Reply With Quote
Rivets and spacing
Iv done a quick search but cant find anything.
What size rivets and what spacing do i need for the floor? the floor is 2mm electro-zinc coated steel btw
MakeEverything
posted on 7/5/09 at 12:35 PM Reply With Quote
2mm?
Bloody hell.
I would use 6mm or even 8mm rivets at about a 4" spacing, maybe 3".
Kindest Regards,
Richard.
tegwin
posted on 7/5/09 at 12:41 PM Reply With Quote
2mm.... should be good for its anti tank mine properties...
2mm ali sheet yes... 1-1.5mm steel sheet yes
www.verticalhorizonsmedia.tv
speedyxjs
posted on 7/5/09 at 01:00 PM Reply With Quote
I meant to order 1.5mm but accidentally ordered 2mm but im not too bothered. Its not going to make a huge difference in weight anyway
omega0684
posted on 7/5/09 at 01:01 PM Reply With Quote
3/8 rivets, 2" apart!
mind you that was with my ali floor
[Edited on 7/5/09 by omega0684]
hughpinder
posted on 7/5/09 at 01:03 PM Reply With Quote
I dont really know what diameter to use, but I thought the usual reccomendation was to space them at centres of 10 times rivet diameter
Regards
Hugh
speedyxjs
posted on 7/5/09 at 01:14 PM Reply With Quote
Originally posted by MakeEverything
2mm?
Bloody hell.
Maybe i should use your avatar?
Mr Whippy
posted on 7/5/09 at 01:37 PM Reply With Quote
2mm?
Bloody hell.
I'd have to agree about the size tbh, 4-5mm ones at about 3inch spacing. Don't know about any hard and fast rule, just go with what looks right
tegwin
posted on 7/5/09 at 01:45 PM Reply With Quote
Hope my maths is correct...
2x2m sheet of mild steel....
1.5mm thick weighs 47Kg
2.0mm thick weighs 63Kg
2x2m sheet of alloy (grade dependant)
2.0mm thick 22Kg
But if you are fitting that jag engine... no.. its not going to make any difference :p
[Edited on 7/5/09 by tegwin]
