Author: Subject: Help required to ID, Hub, caliper & wish bones please
leon51274
posted on 11/5/11 at 04:25 PM Reply With Quote
Hi Men
Not been on here for a while but constantly reading the many useful hints and tips...keep up the good work!
I'm hoping someone would kindly ID my front hubs, calipers and wishbones. Ref number for the Hub is Ford URS 71BB 3108 AE. And the caliper is some sort of m16 ,ref number a bit hard to read but one looks 57R and the other 22R.
The reason for the questions are, the brake discs on full lock are coming in to contact with the bottom wishbone! i'm thinking that something is not right with the combination set up as the calipers were also spaced off the hub with a couple of 2mm washers and the discs looked bloody close the hub.
I can post some pics of the calipers and hubs mounted if that helps?
Many thanks
Leon
Hopefully these pics will be viewable, if not there in my archive.
blakep82
posted on 11/5/11 at 04:32 PM Reply With Quote
looks cortina uprights, with standard sort of calipers, but vented disc? didn't think cortinas had vented discs... which is why i say 'standard sort of calipers'
are the discs bolted to thehubs the wrong way round? look slike you have washers on there to space the caliper correctly? i wonder if you could turn the discs round at all...
________________________
Mal
posted on 11/5/11 at 04:35 PM Reply With Quote
From the bottom upwards:
The wishbones are probably MK ones.
The calipers are M15 (Cortina) ones.
The uprights and hubs are Cortina. The uprights
were forged in Bromsgrove by GKN Garringtons Ltd.
Johneturbo
posted on 11/5/11 at 04:36 PM Reply With Quote
I was also going to say cortina uprights, but then i don't think you asked that question!
big_wasa
Cortina mk 3,4,or 5 uprights. M16 calipers with spacer kit for the capri vented discs.
Wishbones being bent tube look Mk but thats just a guess ?
leon51274
posted on 11/5/11 at 04:38 PM Reply With Quote
Cheers men
So do you think cortinas had non vented discs? This was my thought, that maybe the discs where wrong!
big_wasa
posted on 11/5/11 at 04:42 PM Reply With Quote
Cortinas didnt Have vented disc's. They where fitted to some capri's, the 2.8 at a guess.
This is the spacer kit that you fit to an M16 for the vented disc's
leon51274
posted on 11/5/11 at 04:46 PM Reply With Quote
Excellent, i knew you boys would answer the question.
So, any idea where i can get the kit?
Johneturbo
posted on 11/5/11 at 04:49 PM Reply With Quote
Rally design do lots of cortina stuff
big_wasa
Its already bolted to your calipers.
posted on 11/5/11 at 04:52 PM Reply With Quote
Rally Design have them, or you could venture forth to the perils of eBay:
http://cgi.ebay.co.uk/M16-Caliper-Spacer-Kit-Escort-MK1-MK2-Capri-Cortina-/390311147640?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae05b78 78
Mr Wasa is correct; looks like the spacer kit is already installed.
[Edited on 11/5/11 by MikeRJ]
blakep82
posted on 11/5/11 at 04:53 PM Reply With Quote
the spacer should already be in the calipers. it widens the opening to allow them to go over the vented discs, instead of the narrower solid discs.
i think you need to remove the disc, flip them round (so the disc sits nearer the wheel, and refit. from your photos, i assume the 3 washers are there to space the caliper out to the disc? turn the disc round, and remove the washers i think.
not done this myself, but thats how it looks to me.
phelpsa
posted on 11/5/11 at 06:31 PM Reply With Quote
Nope that's wrong. The current setup is correct, however the wishbones weren't designed to take the wider vented discs into account i expect. Lock stops are the only way.
The 3 washers are there instead of the 4 round spacers shown in the photo that are required when fitting capri vented discs.
[Edited on 11-5-11 by phelpsa]
leon51274
posted on 11/5/11 at 07:22 PM Reply With Quote
ok, i maybe starting to get a little confused...not difficult!
I think phelpsa may be right. If the washers weren't spacing the caliper off and i had a non vented disc on then this would give me the space required to stop the disc touching the wishbone?
If this is the case then do i need to remove the spacer kit and get myself some new discs?
What about if i went down the route of wilwoods m16 caliper? Would i have the same problem?
Appreciate the help so far guys!
