mad4x4
| posted on 27/4/12 at 04:14 PM |
What Engine for a MK indy
Currently have a zetec (old red top) and it is giving no end of problems, what do I chage it to that fits or easily fits the type 9
What about something like sccoby engine or bike or ??
Scot's do it better in Kilts.
ali f27
| posted on 27/4/12 at 04:23 PM |
How about another zetec brand new of gbs £700 bike engine would take patial rebiuld i am fitting a duratec brill engine but not cheap to bolt to a
type 9
MakeEverything
| posted on 27/4/12 at 05:33 PM |
2.9 cosworth V6
Kindest Regards,
Richard.
mangogrooveworkshop
| posted on 27/4/12 at 05:35 PM |
Just get another hundred quid zetec and go for it.......Wrong time of the year to be changing engines.....
We get little enough time to drive in the Scottish summer with out having a car off the road
mookaloid
| posted on 27/4/12 at 06:47 PM |
scooby engine no good - too wide
austin man
| posted on 27/4/12 at 07:02 PM |
Zetecs are usually bomb proof if they have been serviced well.
| posted on 27/4/12 at 08:37 PM |
What sort of problems is the zetec giving you?
They normally dead straight as long as you use the correct oil.
RK
| posted on 27/4/12 at 11:37 PM |
My Nissan is toast too, so I am going to pull it this weekend and have a look. Maybe within a month, or two, someone from the local sports car club
will come over to let me know what the hell I am supposed to look for. So a rebuild is in the cards, and if it all goes haywire, another JDM. I
don't expect to drive much this year.
So I feel your pain. If I were you, I'd go for the new Zetec and be done with it. In the end it is probably cheapest. We can't get them
here, and don't have Type 9's either.
mangogrooveworkshop
| posted on 28/4/12 at 06:13 AM |
Is it the wiring that's the issue
Or the cooling system.......
swapping to another type of engine is just going to bring more grief
mad4x4
| posted on 28/4/12 at 11:18 AM |
It's an emissions problem
Had it since day zero,
Day zero : to much HC & CO2
Year 1 : change to bike carbs - to much HC & CO2
Year 3 : Changed to Mega squirt injection ..... to much HC & CO2
last week fixed an inlet air leak & fitted wide band lamdba -
Yesterday : MOT (2nd this year) failed on emmission again ...... Still in the 4k Range. to much HC & CO2
Ready to throw matches at the thing........ so pissed off.
mad4x4
| posted on 28/4/12 at 11:19 AM |
'bout the same! don't think it will MOT this year - So pissed off
[Edited on 28/404/12 by mad4x4]
RK
| posted on 28/4/12 at 12:05 PM |
Have you checked the thermostat? The MAF dirty?
I have no idea, but I read that somewhere. Can't hurt!
[Edited on 28/4/12 by RK]
mad4x4
| posted on 28/4/12 at 02:13 PM |
Err don;t have a MAF (air flow meter) but have water temp, air temp, air press, throttle pos, wide band lamdba...
thermostat would cause/stop over heating issues but it is emissions i'm having probs with
MakeEverything
| posted on 28/4/12 at 04:48 PM |
Whats your AFR reading?
Mine failed on emissions last time (twice the limit), as a result of the base map running rich etc. Its only now that i have the ASE and WUE settings
working correctly with the injector PW to get an AFR of between 12-14 on idle.
The problem could also be static timing. If the EX valves are opening too early, youll get unburnt fuel in the exhaust, causing a rich reading on the
AFR and high HC.
ETA: I would check the static timing to TDC, and compression test to check valve seat integrity.
[Edited on 28-4-12 by MakeEverything]
Kindest Regards,
Richard.
mad4x4
| posted on 29/4/12 at 08:39 AM |
got afr at about 11-12 i will start a thread and post the ta\bles
what should the static timing be for azetec??
[Edited on 29/404/12 by mad4x4]
MakeEverything
| posted on 29/4/12 at 08:47 AM |
got afr at about 11-12 i will start a thread and post the tables
No idea, but a haynes manual should tell you how to replace the timing belt, which will reset the timing.
Kindest Regards,
Richard.
jacko
| posted on 10/6/12 at 03:16 PM |
How did you sort this problem ? or is it still on going
Jacko
