Author: Subject: MX5 transmission
Slimy38
posted on 14/9/13 at 07:27 PM Reply With Quote
MX5 transmission
For the MX5 knowledgeable people here. I have a 1.6 viscous diff at the moment, with driveshafts and propshaft to suit. I believe that to swap it out for a 1.8 diff I would have to get the corresponding driveshafts and propshaft. But is it only the lengths of the shafts that cause the issue, or do the 1.6 driveshafts and propshaft not even bolt to a 1.8?
If the lengths are different then it doesn't matter (I can just alter wishbone lengths to suit), if it doesn't even bolt up then I'm screwed.
pewe
posted on 14/9/13 at 07:46 PM Reply With Quote
The 1.6 driveshafts are flanged and bolt to the diff whereas IIRC the 1.8's are splined and slide into the diff casing.
HTH.
Cheers, Pewe10
Slimy38
posted on 14/9/13 at 08:15 PM Reply With Quote
The later 1.8's are complete driveshafts as you describe, but the earlier ones have a flange design similar to the 1.6. The top image on here shows what I mean;
http://www.miata.net/garage/diffguide/
A bit further down is another couple of 1.8's, one from an auto. Both of those are also using stub shafts.
Smokey mow
posted on 14/9/13 at 10:15 PM Reply With Quote
Early 1.6 shafts wont bolt to a 1.8 diff. As well as being different lengths the PCD is different.
Later 1.6's used the same diff as the 1.8 and had push in shafts, on those everything is interchangable.
Slimy38
posted on 14/9/13 at 10:26 PM Reply With Quote
That's the sort of info I was after, thanks.
Smokey mow
posted on 15/9/13 at 09:37 AM Reply With Quote
Happy to help.
There's some more dimensions and photos about halfway down this page which gives a bit more details on the differences
http://www.solomiata.com/Drivetrain.html
