Cozza
| posted on 17/5/03 at 01:00 PM |
Sierra Donor
I am probably 80% through the build of my chassis and about to source a donor car. Having read messages on the forum and various other bits and
pieces, I am thinking of going for -
2.0 L Sierra for engine, gearbox, steeering column, pedals, etc
Can I use the diff from this for the Locost or do I need to buy an Escort diff and prop (with brake drums etc)?
Any advice greatfully received
Cozza
stephen_gusterson
| posted on 17/5/03 at 01:37 PM |
unless you want A LOT of work and hassle insorting out the geomety, use a cortina or escort or capri axle.
There are no definitive plans to convert a locost to irs suspension using sierra diff. I did ny own using a diff and it toook a fair while.
following the book reas suspension is as quick a route as you can take.
Also, live axle cars dont excatly handle crap in a locost.
atb
steve
Johan F
| posted on 18/5/03 at 05:48 PM |
Wich sierras are equipped with the 2l pinto engine?
Wich ones has LSD?
/ Johan
chrisg
| posted on 18/5/03 at 06:09 PM |
2 litre ones
cosworth, xr4 x4
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stephen_gusterson
| posted on 18/5/03 at 07:26 PM |
2 litre cars after 1989-90 had the DOHC non pinto.....
slipping up chris!
atb
steve
Cozza
| posted on 18/5/03 at 07:27 PM |
Thanks guys
auzziejim
| posted on 18/5/03 at 11:03 PM |
and you can even get a free 2.0 DOHC (which pushes out more bhp than a Pinto) for free.
Anybody want a 2.0 DOHC with MT75 box for free?? well iv got one now, LOL
cheers
James
James
| posted on 19/5/03 at 10:46 AM |
slipping up chris!
atb
steve
Sorry Steve:
not exclusively. The '205' Pinto came out in 1989 and was around for about 3 years. I've got one!
HTH,
James
James
| posted on 19/5/03 at 10:51 AM |
quote: Originally posted by Cozza
Cozza
Cozza,
If you're 80% of the way through isn't it a little late to go IRS from the Sierra?
You're gonna have to chop the prop around anyway (or get one made by someone) so it doesn't massively matter what it's from!
HTH,
James
stephen_gusterson
| posted on 19/5/03 at 11:58 AM |
slipping up chris!
atb
steve
Sorry Steve:
HTH,
James
I kinda knew that, having seen differnet descriptions of when it changed over in the haynes manual for sierra and granda. There is also the problem of
stockpiled cars extending dates
I have a relation that works at ford. The discount cars they can buy are very often 'old spec' models that are from a recent trim level
change.
atb
steve
chrisg
| posted on 19/5/03 at 05:14 PM |
Whoo hoo I'm right !
Aren't I?
I dunno
Johan F only wants one for a westfield anyhoo, so I don't care
Chris
stephen_gusterson
| posted on 19/5/03 at 05:50 PM |
lets go for a tie.
a nice stripy one in pink and yellow
| posted on 19/5/03 at 06:52 PM |
My block is a 205 and it's from a 1987 Sierra. Engine tallied with log book. When did they start from?.
yours, Pete.
James
| posted on 19/5/03 at 07:46 PM |
yours, Pete.
I hadn't heard that before... interesting.
2nd Sierra fact for the day!
I'm a bit confused as I've read about it coming out in March '89 from several sources.
Oh well, that's Ford for you- bloody confusing!
James
Johan F
| posted on 19/5/03 at 09:20 PM |
Ok, for me who doesn't speak Ford.
What is special about the 205?
Which cars where they in?
Wich gearboxes are common in the sierras? Type 9? The 75?
Isn't there any good pages about Ford engines, so I don't have to bug you about it?
/ Johan
James
| posted on 20/5/03 at 10:36 AM |
/ Johan
205 is injection model. Comes from '205' being cast on side of block.
Apparently block, rod and crank strength is improved over original.
Breathing of Cylinder head is better too.
See:
http://www.pumaracing.co.uk/pinto.htm for some more info.
They were in both Sierras and Granadas.
Both the Type9 and the MT75 gearboxes are in Sierras.
HTH,
James
gjn200
| posted on 21/5/03 at 06:17 PM |
205 did come out earlier than 1989, it was in the glsi, also arnt cossie blocks 205? Oh and fact 3 for ya, the cossie blocks where the only ones
x-rayed too.
<- Me!
Johan F
| posted on 21/5/03 at 10:46 PM |
James
Ok then, but wich type is mated with the 2l Pinto?
/ Johan
PS
Isn't the cossie engines DOHC?
James
| posted on 22/5/03 at 11:08 AM |
Johan,
Sorry, should have said before:
Pinto/CVH- type9
DOHC (8valve)- MT75
The cossie is DOHC but it's a 16valve head on the '205' block.
gjn200,
Thanks for no 3.
HTH,
James
timf
| posted on 22/5/03 at 11:34 AM |
don't forget the 200 block
as fitted to the 4x4 cossie and suposed to be stronger than the 205 blocks !
James
| posted on 22/5/03 at 01:07 PM |
Wow! Isn't this thread getting educational!
Got any links about it as never heard of it before.
James
ned
| posted on 22/5/03 at 01:30 PM |
i just saw a brand new 200 block for sale on the racecar forum quite a good one for buying
second hand performance/race parts.
Ned.
beware, I've got yellow skin
