RickRick
posted on 9/12/08 at 04:29 PM |
More Urgent R1 Help
I've got a map now from stuart, who passed with the same setup as me, but mine still won't run infact it's worse now, it'll
start and almost idle, and gas kills it, and quite often it'll just fire a couple of times, turn over a couple, fire a couple
oh also the plugs seem to be quite wet
btw 2004 r1
[Edited on 9/12/08 by RickRick]
stuart_g
posted on 9/12/08 at 04:51 PM |
You will have to slightly tweak the map to suit your airfilter, Cat etc. I will send you the map that I started with before altering at the SVA
station which the engine should run on ok and you can compare the two.
My engine at SVA wouldn't run very well and if you push the throttle pedal too fast it will stop, but it did pass. I only loaded that map for
the emissions test, I had another map for the other parts of the test. All you are interested in is getting the emissions right just for that part of
the test. The tester doesn't care what it runs like.
adithorp
posted on 9/12/08 at 06:49 PM |
Chris is right (as usual). You only need small changes. I started with a blank map and only changed the areas where the test is done plus a bit either
side.
adrian
http://jpsc.org.uk/forum/
RickRick
posted on 9/12/08 at 08:06 PM |
just had another go with the pc disconnected and had the same results bit of running bit of stopping
StevieB
posted on 9/12/08 at 08:34 PM |
Have you had the engine running at all yet?
adithorp
posted on 9/12/08 at 08:38 PM |
That description sound like a knakered fuel pump or poor presure now you've eliminated the PC. Have you got a filter between the tank and pump?
Crap from the tank can screw them up if you've not got one. Is there any blockage in the pick up? That would give the same symptoms.
adrian
RickRick
posted on 9/12/08 at 08:40 PM |
even though the plugs look wet?
i'll check the filters clear, any idea's how to test the pump? is it ok to loop it back to the tank to check it's got plenty of
flow
RickRick
posted on 9/12/08 at 08:59 PM |
i've got a seperate filter, sytec i think it's called, i know there's a difference but i've no idea how else i could check
the pumps working!
adithorp
posted on 9/12/08 at 09:00 PM |
Try switching on and letting the pump prime and switch off. Then CAREFULLY remove the feed pipe to the fuel rail. You should have residual pressure
and get a small/brief spray if the pumps/feed is good. If its fooked you'll get a dribble.
Wet plugs doesn't sound like this though. Didn't see/read that.
adrian
stuart_g
posted on 9/12/08 at 10:01 PM |
The map I sent was just altered in the region were the test is done. mine ran very poorly after the emission test was passed with the values to get it
through the test. I just swapped to a known working map for the rest of the test and had no problem.
chockymonster
posted on 12/12/08 at 10:44 AM |
My car drove to the station on the SVA map.
Perfect pickup through the range and a really smooth idle.
If it's for the 2002/2003 R1 then I can email it across to you.
