marcus_uk
posted on 20/2/09 at 11:59 PM |
What is the best car for a donor car ?
Hi guys and gals,
I'm new to all this, but have a family member who has restored an old mini clubman and has given me the passion to build my own locost car.
The thing is i dont know which donor car i should buy/source ?
I want to be able to buy parts eaily and cheaply ... if anyone has any help and able to point me in the right direction i would be very greatfull.
Thanks in advance
Marcus
blakep82
posted on 21/2/09 at 12:01 AM |
most would say sierra. theres more exciting engines to be had though
________________________
ReMan
posted on 21/2/09 at 12:14 AM |
Buy this book,
http://www.amazon.co.uk/Build-Your-Own-Sports-Car/dp/1844253910
Then ask some more questions
mark chandler
posted on 21/2/09 at 12:26 AM |
If it was that easy, a worn out car will give you worn out engine, gearbox and axle so to get a quality finished product may end up costing more than
sourcing the various bits seperately if you end up reconditioning everything seperately.
If you are making your own frame and bones etc then any RWD car could be a good donor as you modify what you build to suit. If you want to follow the
easier route then sierra is the car of choice as plans exist for this.
Also what do you want to experience, manic excelleration, sequential shifts and +10,000 RPM is the world of BEC's in which case all you need is
are axles propshaft and a big bike engine so getting seperate bits should ultimately be cheaper.
The flip side is use a donor with good resale value on the parts you do not want and break even, but that usual involves a broken car on the drive for
ages... not good really.
Paul TigerB6
posted on 21/2/09 at 01:29 AM |
My advice - forget about the donor car and think about what kit you want to build. The kit supplier can advise on the best donor to suit your needs. I
have seen so many posts on various forums with people who want to build what will be a £5k - £10k+ kit car just because they have been given a £200
donor.
Any kit car available today will have parts cheaply available. Build the car you want and go for whatever donor that requires
Steve Hignett
posted on 21/2/09 at 01:53 AM |
Hi Marcus,
welcome to the Forum.
I would suggest that you put your location in your ID. That way people local to you may be able to help out with your Donor Car Search!
Secondly I would add that the sentiments above ring pretty true - evaluate which kit you intend to build (with which engine - OBV BEC!) and then
source the correct Donor, or Donor pack and go from there.
RK
posted on 21/2/09 at 02:08 AM |
Listen carefully to what people are suggesting. It can get very expensive otherwise. Besides the cost, it can become very unpleasant, and generally
not a lot of fun.
Danozeman
posted on 21/2/09 at 10:06 AM |
Sierra is the norm but are getting harder to get.
Id get a dogged Mazda mx5. Might cost a bit more but youl get a good set of running gear.
As already said. Decide on which kit you want first and then what u want to use it for. Ie track use or just road.
[Edited on 21/2/09 by Danozeman]
Dan
marcus_uk
posted on 21/2/09 at 10:58 AM |
Thanks guys for the fast replys, I'm based in Crewe Cheshire.
At the moment i'm leaning towards a bike engine, as i have a bike in the garage ... so i kinda know about the engines. But i'm not after
something thats going to blow my socks off. Beside the kit i want to build it from scratch. I have the tools to do it. Just not the information to
build it. Is there anything different from building from the book to what i will need to do if i use a bike engine ? Will the engie bay need to be
bigger or shorter ? anyone got any tips ?
Marcus
Ian D
posted on 21/2/09 at 11:22 AM |
I think this peice from John Ruskin sums up building a kit car. In particular around integration. Buying a package from a supplier may work out
cheaper in the long run if your not sure.
best of luck
Ian
It is unwise to pay too much,but it is worse to pay too little. When you pay too much, you may lose a little money...thats all. When you pay too
little,you sometimes lose everything because the thing you bought was incapable of doing the things it was bought to do"
The common law of business balance prohibits paying a little and getting alot...it cannot be done. If you deal with the lowest bidder it is as well to
add something for the risk you run. And if you do that you will have enough to pay for the something better.
There is hardly anything in the world that some men cannot make a little worse and sell a little cheaper,and the people who consider price only are
this man's lawful prey.
JOHN RUSKIN 1819 - 1900
quinnj3
posted on 21/2/09 at 12:03 PM |
another thing to remember is that any book you buy will be a rough guide only. Although it will definately be invaluable. The book mentioned
previously should be bought and I'd also recommend 'How to Build Motorcycle-engined Racing Cars'. Again it is a rough guide,
definately no instruction manual, but it will help with understanding suspension and also as the title suggests the installation of a Bike engine.
Good luck
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
marcus_uk
posted on 21/2/09 at 12:59 PM |
Thanks for all the information, which is sound advice. But i was wondering, does everyone now a days build their own chassis or do you get a kit ?
Is it easy to build your own chassis ? or is it better to use a kit ? Has anyone got any diagrams for a chassis ?
Thanks again for your help everyone
Marcus
chrisg
posted on 21/2/09 at 02:38 PM |
quote: Originally posted by ReMan
Buy this book,
God bless you
The cheque's in the post...
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
mr henderson
posted on 21/2/09 at 03:08 PM |
Marcus
You should buy the book anyway. When deciding whether to build your own, or not, you need to consider your time as well as the cost. Sometimes
it's better to buy the kit ready made and get on with building it up (you will still have LOTS to do). On the other hand, you might get more
fun. or satisfaction, from building everything yourself, as far as possible.
If it was me I would probably make the chassis but buy all the wishbones, uprights etc. In the end what is it that you want the most, the finished kit
to drive around in, or the enjoyment of building it. There's a graph curve there and you need to decide what point it intersects with your
requirements, if you see what I mean
John
marcus_uk
posted on 21/2/09 at 03:37 PM |
Ive got both books, it's just i've been told that the chassis diagrams are not 100% so i'm unsure on if i should follow them 100% or
not and use them as reference.
I dont mind if this build takes me 2 weeks or 2 years. And as this is my first time building one i just want to learn things. But i still want a great
final design.
I would love tobuild everything from scratch but i want to now if there is information about each part i need to do
But i'm finding information out as i go along ... now this is the fun part lol.
But one last thing thanks guys for all your information, i'm a new starter to all this and the wealth of information on here is crazy.
Marcus
Steve Hignett
posted on 21/2/09 at 03:53 PM |
I'm about 7 miles away from you and have a scratch built locost with a Fireblade engine in it that I am working on right now, if you want to
come and have a look?
marcus_uk
posted on 21/2/09 at 04:55 PM |
I would like that very much steve. Ill will call you later on today, as at the moment i have guest around.
ReMan
posted on 23/2/09 at 11:37 PM |
It's not ChrisG is it?
I considered making my own chassis, probably had the skill to do it, but decided to save 6 months and get into the main build quicker by buying the
chassis from a well known manufacturer and getting cracking.
Decisions, decisions
[Edited on 23/2/09 by ReMan]
