<<  1    2  >>
Author: Subject: Its come, its come, its come, its come, its come, its come, its come!!!
speedyxjs
posted on 25/2/09 at 05:37 PM Reply With Quote
do you think im happy?
Sorry for the crappy pics, its hard to move in the garage atm.
neilj37
posted on 25/2/09 at 05:45 PM Reply With Quote
Is that a 2.0l pinto
dogwood
posted on 25/2/09 at 05:46 PM Reply With Quote
I take it, it's come then?
[Edited on 25/2/09 by dogwood]
FREE THE ROADSTER ONE…!!
speedyxjs
It would thrash a pinto
DarrenW
posted on 25/2/09 at 05:48 PM Reply With Quote
How? First to reach the sea bed or would squash one if dropped from a height (of over 2 feet)????
MikeR
posted on 25/2/09 at 05:49 PM Reply With Quote
its far heavier
speedyxjs
What does a pinto actually weigh?
Miks15
posted on 25/2/09 at 05:51 PM Reply With Quote
i get the impression your happy about somehting but cant quite put my finger on what
Is your avatar going to be the "after" shot?
Ben_Copeland
posted on 25/2/09 at 05:52 PM Reply With Quote
Eh? Whats come??
Ben
Locost Map on Google Maps
Enter Your Details Here
flak monkey
With all anciliaries about 130kg
Sera
http://www.motosera.com
jacko
posted on 25/2/09 at 05:53 PM Reply With Quote
Very old diesel truck engine ?
what is that going in ? a generator
speedyxjs
posted on 25/2/09 at 05:54 PM Reply With Quote
No. Thats a XK engine. I just likes that one 'cos its polished
speedyxjs
posted on 25/2/09 at 05:56 PM Reply With Quote
Well that one weighs 240kg Im still on target to build the car less that 1 ton
Paul TigerB6
posted on 25/2/09 at 06:00 PM Reply With Quote
Funny you should say that - i was about to say it was used to power the Titanic!!!
Volvorsport
posted on 25/2/09 at 06:02 PM Reply With Quote
what is it ?
www.dbsmotorsport.co.uk
getting dirty under a bus
speedyxjs
posted on 25/2/09 at 06:06 PM Reply With Quote
Jaguar 3.6 AJ6 engine to replace the 2.9 from the donor. Cost me all of £71 Its gonna have a strip down and rebuild at the weekend.
From wiki:
The 3.6 was the first AJ6 engine, debuting in 1983 on the XJS. It had DOHC 4-valve heads with a 91 mm bore and 92 mm stroke. Power was 165 kW (221 hp) with 325 N m (240 ft·lbf of torque. Power was reduced to 201 hp (150 kW) for versions having catalytic exhaust system. Early versions of the 3.6L AJ6 as used in the 1984 - 1987 XJS cars had a conventional distributor type of ignition system with electronics within the distributor body. This early AJ6 ignition system is nearly identical to the system used on the XK engine in the Series III XJ6 cars. The Lucas fuel injection system on the 3.6L AJ6 engines in these early XJS cars sensed engine load using a Manifold Air Pressure (MAP) sensor just like the V12 cars from the same era. Later 3.6L AJ6 engines as used in the 1986-1989 XJ40 cars had a crank sensor type of ignition system with a bare distributor that only carried the spinning ignition rotor inside the distributor cap. The fuel injection system used on the later 3.6L AJ6 engines used a hot wire Mass Air Flow sensor to determine engine load.
posted on 25/2/09 at 06:09 PM Reply With Quote
240kg Wow. That sure ain't alloy....
Paul TigerB6
posted on 25/2/09 at 06:12 PM Reply With Quote
Its cast from melted Pinto's - no wonder it weighs more than half a complete BEC!!
Dangle_kt
posted on 25/2/09 at 06:13 PM Reply With Quote
I'm sure it will sound wonderful, and if your car is under the 1000kg will have over 200bhp per ton, which is still more than enough UMPH!
Good on you, and good bargain hunting.
What gearbox will you mate it to, and will it need a much different transmtsson tunnel design?
speedyxjs
Also taken from wiki:
It is uses an aluminum block to reduce weight
I got the weight from an american website which was in pounds so that may be wrong (i think american lbs are different to uk?)
posted on 25/2/09 at 06:16 PM Reply With Quote
That's huuuuuge.
Get it weighed in for scrap, you'll get at least 10x what you paid for it.
Phil
Richard Quinn
posted on 25/2/09 at 06:24 PM Reply With Quote
Originally posted by speedyxjsPower was reduced to 201 hp (150 kW) for versions having catalytic exhaust system.
... and to think that my little BMW 4 pot all alloy oil burner is 204bhp and is doing 46mpg
I'll admit it won't sound as nice though!
speedyxjs
posted on 25/2/09 at 06:26 PM Reply With Quote
Turbo diesel?
focijohn
posted on 25/2/09 at 06:37 PM Reply With Quote
was that 71 quid running?
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
speedyxjs
posted on 25/2/09 at 07:05 PM Reply With Quote
It was before it was removed. It been out for about 2 months.
<<  1    2  >>
