Coopz
| posted on 17/4/09 at 12:12 PM |
Diff again!
After deciding, to keep the 3.62 open diff M K supplied in a donor package to start off with I cleaned the whole thing up and got it sprayed then
fitted it and driveshafts on. Then when in the garage this morning it had 3 D (83BG-AD25-BA) printed on the side am i right in saying that it is
actually a 3.92! I will be gutted if it is!
Mr Whippy
| posted on 17/4/09 at 12:27 PM |
can't you put some paint or pen marks on the input/output flanges and turn it over? if you turn the propshaft input 3.92... times then the
output shaft should turn once, should be a very quick check
[Edited on 17/4/09 by Mr Whippy]
jacko
| posted on 17/4/09 at 05:01 PM |
This any good for you
Jacko
  no2
  No1 and as far as a know are correct
  no3 the info on the 5 photos came of the internet
