mrwibble
| posted on 7/8/09 at 09:15 PM |
sierra 1.6pinto v sierra 1.8 cvh
both have type 9s, essential for my fury build. the 1.6 has done more miles 111k and the 1.8 cvh has done 81k.
not bothered about the engines themselves as i'm going to zetec it. but i'm wondering if their will be any advantage from either in the
way of diff ratio and gearing. i'm building a road car with most likely a 2.0 ze after market management. although i haven't ruled out a
1.6 4age 20v from RaW.
will the be significantly more wear on the 111k box/diff assuming both have not been abused.
thanks for any info.
wibble
Slater
| posted on 7/8/09 at 10:05 PM |
My type 9 had done 210,000 miles in the sierra and 1000 miles in the MAC#1, it works perfectly. So I would say either one will be OK.
[Edited on 7/8/09 by Slater]
big_wasa
| posted on 7/8/09 at 10:08 PM |
Not alot in it but the pinto will be older.
Dusty
| posted on 7/8/09 at 11:38 PM |
Could go CVH because the sump can be shortened and used on both CVH and zetec and the starter can also be transferred. Gearbox is likely to be in
better nick too as its the later type 9 and the cvh couldn't pull the skin off a rice pudding so won't have stressed it too much.
ss1turbo
| posted on 8/8/09 at 07:07 AM |
..and unless you get a pre-95 Zetec, then any of the above will work better for IVA
I'd go for the CVH for now as a lot of what you do (apart from the top hose routing) can be reused when you Zetec (exhaust on the right side,
engine mounts, etc). Is it a carb or injection 1.8?
Long live RWD...
mrwibble
| posted on 9/8/09 at 11:38 AM |
heres a of what i believe is a pinto 1.6. have asked for more info on engine.
[Edited on 9/8/09 by mrwibble]
