Author: Subject: Mazda MX6
uncledum1
posted on 8/1/10 at 02:55 PM Reply With Quote
Mazda MX6
Hello, has anyone ever used a Mazda mx6 2.5 v6 for a donor car?. I have a perfectly good one but will put back on road or use for a kit car donor. Any help will be appreicated.
Steve G
posted on 8/1/10 at 03:01 PM Reply With Quote
I think Clairetoo uses a Mazda V6 in her car. I think you'd only get to use the engine in a kit though so I wouldnt build a kit car just to use the engine.
Edit: In fact - i wouldnt build a kit car just because you have a potential donor car! Pick the kit and get a suitable donor car should always be the way to go about deciding what to build
[Edited on 8/1/10 by Steve G]
uncledum1
posted on 8/1/10 at 03:09 PM Reply With Quote
I was building from stratch and dont wont a kit really. Just cant seem to find a donor car without spending loads. just trying to use what i had.
Steve G
posted on 8/1/10 at 03:14 PM Reply With Quote
Problem is you may end up spending loads more overall by trying to get something to work than you would on a more suitable donor in the first place. For example, a custom bellhousing if needed and 2 exhausts to suit the V6 will probably cost a lot more than an MX5 or Sierra donor would.
Not trying to put you off at all, just trying to stress that its the bigger picture that needs considering at the outset.
uncledum1
posted on 8/1/10 at 03:31 PM Reply With Quote
thankyou for your advice, will need to think where to go from here.
tomprescott
posted on 8/1/10 at 03:50 PM Reply With Quote
Sorry but I disagree. If you don't want to build a kit and are looking more at building a special, whether it be 7 shaped or not it doesn't matter!
If you have a mazda that you want to use then use it, thats the great thing about these projects! What is it that you want to build? You could make a completely custom car just built around the mazda components.
The only word of warning I would say is that the further you stray from the beaten path the longer it will take you to get over the inevitable hicups, but don't let that put you off - thats half the fun of building your own car and only adds to your sense of achievement once you're finished!
Steve G
posted on 8/1/10 at 03:58 PM Reply With Quote
Just so long as you understand or can learn about suspension and chassis design, and have the ability to design a car from scratch then i'd agree.
uncledum1
i think alot of depends on how big the engine is once its out. i have no set plans yet as it will be a completely custom build.
uncledum1
posted on 8/1/10 at 04:01 PM Reply With Quote
At least i have a complete workshop and rebuild cars as a hobby for people. I like doing body work just never done a full car before.
tomprescott
posted on 8/1/10 at 04:05 PM Reply With Quote
As above really, you've got the space and most of the skills necessary. If you're careful with your planning and research then you'll be fine. Like Steve says though, poor design of suspension in particular will mean you'll get a car that will handle like a pig!
Good luck with it!
clairetoo
posted on 8/1/10 at 04:35 PM Reply With Quote
The Mazda V6 is very small - it's shorter in both length and height than a crossflow (but more than a bit wider ) and only 110 kgs bare.......
I fit them to Mx5 box's with an adapter plate , so no `custom bellhousing' for me
Its cuz I is blond , innit
Claire xx
Will weld for food......
uncledum1
posted on 8/1/10 at 05:50 PM Reply With Quote
you have some great pics Clairetoo. thanks for your advice. hope to keep in contact with you for any other problems.
marcjagman
posted on 8/1/10 at 06:33 PM Reply With Quote
Clairetoo, where did you get thadaptor plate and roughly how much?
RK
posted on 8/1/10 at 08:57 PM Reply With Quote
It's really about how much money you have. That will dictate everything.
posted on 8/1/10 at 10:10 PM Reply With Quote
Didn't know that... sounds like a pretty good choice of engine!
It's Evolution Baby!
iti_uk
Builder
Posts 163
Registered 13/10/08
Member Is Offline
Photo Archive Go!
Building: The KLMX-5 ('97 MX5 w/Mazda KL 2.5L V6)
posted on 11/1/10 at 12:46 PM Reply With Quote
You're obviously not familiar with Claire. I'm not sure there's much on that car she hasn't made herself...
Chris
