DAN-MNR-ZX12R
posted on 13/3/10 at 12:26 PM |
Big gaping hole
Hi guys,
I've cut a hole in my side panel for my exhaust to sneak through. It's not the ugliest hole in the world to be fair looks quite well,
but... I've seen a few cars knocking about with a black (poss carbon) panel that surrounds the manifold as it passes through the body.
They are rectangle in shape and I would like one very much
mark chandler
posted on 13/3/10 at 12:59 PM |
If you put a bit of U trim around this makes gaping holes look much neater, how about a crafted bit of thin ali polished up?
doddy
posted on 13/3/10 at 01:19 PM |
maybe a stainless gear lever surraund typr of thing
richardh
posted on 13/3/10 at 06:03 PM |
nice thin polished ali me thinks
Time for a change!
ReMan
posted on 13/3/10 at 06:06 PM |
Or both lie mine.
Ali for the hole u trim for the SVA, and it's still on 4 years on!
![](/galpreviews/180_8010s.jpg) ![exexit](/gallery/180_8010s.jpg) exexit
Humbug
posted on 13/3/10 at 07:22 PM |
I'm assuming that you've got fibreglass panels? You could make some ali trim with extra material inside the hole, make up a former from
wood, drill rivet holes and screw it to the wood, then bang down the insides of the trim with a rubber hammer to 90 degrees. Remove from the wood, the
tap thin inside edges over a bit more.
I did something similar when I changed from over the rail exhaust to through the side panel, just this was a bit of a larger patch
![](/galpreviews/a1111191-2008-04-05 exhaust hole patch.jpg) ![Rescued attachment 2008-04-05 exhaust hole patch.jpg](/gallery/a1111191-2008-04-05 exhaust hole patch.jpg) Rescued attachment 2008-04-05 exhaust hole patch.jpg
Steve Hignett
posted on 13/3/10 at 11:28 PM |
What size piece of carbon would you need to use?
