Author: Subject: Donor car For US / Canadien Builders
bertus76
posted on 16/3/10 at 03:13 AM Reply With Quote
In Canada the suggested donor cars are not available. I used a 1980 Olds Cutlass
It worked great, but you will have change a couple dimensions
blakep82
posted on 16/3/10 at 03:16 AM Reply With Quote
makes a very big car
you'll need to reduce your avatar size, but looks pretty good
edit: lol you have
[Edited on 16/3/10 by blakep82]
________________________
bertus76
posted on 16/3/10 at 03:18 AM Reply With Quote
Sorry, and just did
I thought it would do it automatic
My car is 12" longer, 6" wider and a bit taller
And to handle the power and torque, i didn't use any aluminium and round tube in the chassis
blakep82
posted on 16/3/10 at 03:24 AM Reply With Quote
good work
welcome to the forum btw its a bit late in the day (3.20am now, i really should get to bed lol) to get the proper LCB warm welcome from everyone though
theres a few canadian builders on here, well, you're the third i can think of
sucksqueezebangblow
posted on 16/3/10 at 09:24 AM Reply With Quote
I'm guessing that one of the best donors for US/Canada would be a Miata (MX5).
P.S perhaps I misunderstood your comment about round tube but round tube is actually stiffer and stronger than equvalent size square tube.
FFTS
posted on 16/3/10 at 09:26 AM Reply With Quote
Go to bed!!!!! No.. not you !! You should be getting up! No not you... the one that I meant before, not the one in the other country place.
Oh do whatever you like
Welcome to the forum. I live in the mad house
Chris.
cd.thomson
posted on 16/3/10 at 09:29 AM Reply With Quote
always impressive when people break the mold and have the skills to adapt the basic principles.
looks good!
welcome to the forum.
Craig
blakep82
posted on 16/3/10 at 10:40 AM Reply With Quote
lol me then?!
Canada EH!
posted on 16/3/10 at 03:13 PM Reply With Quote
Welcome to the madhouse, by the way you will learn a new language here, called English, harder to understand than Canadian EH!
bertus76
posted on 16/3/10 at 04:00 PM Reply With Quote
Thanks all,
Btw, I replaced the 19mm round diagonal tubes with 25 mm square, the same as the rest of the frame.
eddie99
posted on 16/3/10 at 04:06 PM Reply With Quote
As said above, i would have thought MX5 would be best!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
bertus76
posted on 16/3/10 at 04:13 PM Reply With Quote
I am sure the mx5 works great.
But since I was going to build one, I thought i might as well use a V8, it wouldn't take anymore time and its something different.
The Olds and Chev monty carlo are based on the same frame / parts and very cheap and plenyfull
sucksqueezebangblow
posted on 18/3/10 at 12:07 PM Reply With Quote
What about uprights/hubs drive train etc, arn't they a bit heavy for a locost?
bertus76
posted on 18/3/10 at 05:39 PM Reply With Quote
Not to bad, I made my car 48" wide. and it worked fine with rear axle from that car. The V8 is a bit heavy. I put mine on a scale and the weigth is about 1750 lbs / 800 Kg with a full tank of gas, and all the body panels made out of steel. It is also 12" longer.
Once i put in the proper engine, it will shave off another 60 lbs.
RK
posted on 19/3/10 at 10:36 PM Reply With Quote
Whatever works! Mine is regulation book sized, but Miata parts and Nissan engine. Still found it hard to do here in Canada (near Ottawa)
bertus76
posted on 20/3/10 at 10:38 PM Reply With Quote
Here in Saskatchewan it was a very easy process to get the car registered. I was pleasantly surprised. The next couple cars i will build after this one might use a different drive line. But the spindles worked out fine, i would use those again since i have the jigs build for the control arms
