Author: Subject: espace v6
mazsparks
posted on 19/4/10 at 05:04 PM Reply With Quote
espace v6
A mate of mine called me from the breakers and said there was a v6 espace.
I don't really know anything about it, any comments.?
It's 24 valve but thinking FWD, has anyone done this and then perhaps taken a different drive shaft or even made a carbon fibre one. That's probs a bit overboard, but any comments welcome.
prawnabie
posted on 19/4/10 at 06:04 PM Reply With Quote
Its a terrible engine, shared with the peugeots of that era. There are much better v6 engines with much better tuning potential around for the same or less money.
mazsparks
posted on 19/4/10 at 06:18 PM Reply With Quote
can you suggest anything, ideally v6, with older electrics.
Many thanks.
flibble
posted on 19/4/10 at 06:27 PM Reply With Quote
Mazda KL-DE from a mx-6/probe would be my choice, wish I'd gone that way from the start
MakeEverything
24V Cosworth V6 with megasquirt.
Megasquirt: £200
Engine: £150
Type 9: £50
Bellhousing: £150
Jobs a goodun.
[Edited on 19-4-10 by MakeEverything]
Kindest Regards,
Richard.
Volvorsport
posted on 19/4/10 at 06:28 PM Reply With Quote
what year is the espace , and are you sure its 24v ?
im interested in it .
www.dbsmotorsport.co.uk
getting dirty under a bus
mazsparks
posted on 19/4/10 at 06:32 PM Reply With Quote
pretty sure its 24v, ill have to find out.
Its a write off though, havent seen it so i really dont know.
mazsparks
posted on 19/4/10 at 06:34 PM Reply With Quote
2.5 v6 24v mx-6, would the insurance be rediculous on that?
speedyxjs
posted on 19/4/10 at 06:40 PM Reply With Quote
Isnt the mazda lump the same as the ford?
flibble
posted on 19/4/10 at 06:45 PM Reply With Quote
Don't think engine size made much difference at all on my kit insurance, not had much experience in that field though.
Same as the Ford probe, different to all others (and lovelier in my eyes ), Everytime I see a pic of clairetoos car it gives me goosepimples
Madinventions
posted on 19/4/10 at 07:08 PM Reply With Quote
I went from a 1.25 with 75bhp to a 1.7 with 125bhp, and my insurance went down by £50 to £117.
That Renault V6 engine is a pony though - go for the Mazda one!
View my band website:
http://www.shadowlight.org.uk
mazsparks
posted on 19/4/10 at 08:01 PM Reply With Quote
KL-ZE 2.5 DOHC V6? don't know much about it at all, can you tick some boxes?
rear wheel drive?, is dohc ok for mcsorley 442? cant remember what i was reading about sohc being better.
Also if this is the mk2 there is A, E or J Spec.
As I say i know nothing about this mazda.
Ta
... just read the kl-ze is the j spec 200bhp
[Edited on 19/4/10 by mazsparks]
clairetoo
posted on 19/4/10 at 08:39 PM Reply With Quote
I've got a KLDE in my Fury - and its a sweet little engine - small , light and revvy .
Mine (and a few others I have done.....) is rear wheel drive - just an adapter plate and special flywheel needed to connect it to an Mx5 gearbox .
With throttle bodies and megasquirt it should be putting out close to 200 BHP , and sings all the way to 8000 RPM
Its cuz I is blond , innit
Claire xx
Will weld for food......
ettore bugatti
posted on 19/4/10 at 08:57 PM Reply With Quote
The later Espace (97 onwards) have transvere located engines (and boxes) and the V6 24V is not as bad as the early Douvrin engines.
Plenty of power (Clio V6 upto 250hp) and quite economical too. Reliable is good too (with exception of the ignition coils)
Would be an excellent donor for a Avantime replica
[Edited on 19/4/10 by ettore bugatti]
Volvorsport
posted on 19/4/10 at 09:13 PM Reply With Quote
if it is a later one , its a fine engine , a 60deg v6 .
if its an earlier one and 24v - then you young ones no nothing about venturis and alpines with these engines in .
the very early odd fire engine is definitely something to miss .
MakeEverything
posted on 21/4/10 at 06:46 AM Reply With Quote
Check for parts availability and costs first.
I got rid of my renault engines because parts were rediculously expensive and any tuning information seemed to be a trade secret.
The kit came with a 2.2 renault engine already fitted, and was pretty bomb proof, though with 128hp (from new, probably more like 90 to 110 in mine) it just didnt seem to have the power i wanted.
Now im fitting a 24V V6 cosworth lump on Megasquirt and throttle bodies, which should give me anywhere between 230 and 260hp.
Kindest Regards,
Richard.
