Author: Subject: Brake master cylinders
mcg
posted on 9/6/10 at 11:15 AM Reply With Quote
Another question!
I am building a pedal box same as Haynes design and need to source the brake master cylinders for a balance bar set up. Car will only be used for track days. What is the cheapest way to source them with out compromising on safety? Been quoted £30quid from a breakers for a master with servo (they wont sell it without servo), but seems a little expensive. Any suggestions would be great. Cheers.
matt
jossey
posted on 9/6/10 at 11:26 AM Reply With Quote
eurocarparts do them cheap the new ones.
.6 and .7
i am using drums at the back so i used normal sierra one. which mrwibble sold me which was nice of him :O)
mcg
posted on 9/6/10 at 02:49 PM Reply With Quote
cool - thanks for the info - I'll give a call.
RazMan
posted on 9/6/10 at 02:50 PM Reply With Quote
You probably wouldn't need a servo on a track car so why not just get new Girling m/c and a bias bar?
Get your pedal design right along with the correct size m/c and caliper pistons and you will have total adjustability and light weight.
Raz
prawnabie
posted on 9/6/10 at 04:18 PM Reply With Quote
What did you ask the scrappie for exactly? It sounds like they are offering you a standard master cylinder which will not be compatible with a bias bar setup.
You will need two seperate single line cylinders for your pedal box.
