Author: Subject: Granadas - all 7.5 inch diff and 5 stud hubs?
posted on 4/9/10 at 09:08 PM Reply With Quote
As title, are all Granadas fitted with 7.5" diffs and 5 stud hubs...?
Mark Allanson
posted on 4/9/10 at 09:10 PM Reply With Quote
Scorpio's have 4 stud hubs, unsure about the diffs
mcerd1
posted on 4/9/10 at 10:11 PM Reply With Quote
my 2.0 pinto ones both had 7" diffs with bolt-on shafts and 5 stud hubs
jollygreengiant
posted on 5/9/10 at 12:26 AM Reply With Quote
Late Scorpios had 4 stud wheels with same PCD as Sierra's.
The Rear subframe was designed to take 7.5" diffs on all granada's and scorpio's. but either 7 or 7.5 could be fitted. The late scorpio's had slightly more cooling fins on the rear plate of the diff (IIRC). Also the late scorpio Diesels (definately, but might be all late scorpios) had heavier rubber seals on the mounting faces for the bolt on CV joints AND thicker diameter bolts to hold them on (by 1mm extra on the diameter IIRC).
The outer wheel drive plates are interchangeable between all Grandas and scorpios.
Hope this helps.
posted on 6/9/10 at 01:32 PM Reply With Quote
Thank you!
Spotted a possible donor and wanted to check.
