Andy_B
| posted on 15/10/10 at 10:47 AM |
Got my donor !!!
Just purchased a 1991 ford granada scorpio for 200 quid its the 2.0 DOHC engine and what looks like MT75 box which is perect or my chassis !! five
stud wheels though but can work around this...its got full leather and some other bits and bobs i am hoping to sell on to cover its purchase cost
...some questions though ...are there any desirable bits i need to be careul with to sell on ...and has anybody got any experience on using a granada
for a donor ? loads of electrics will be unused and stripped out ...but thats my occupation so shouldn be a prob !!
mcerd1
| posted on 15/10/10 at 03:23 PM |
which chassis are you using ?
Andy_B
| posted on 15/10/10 at 03:30 PM |
Its the saturn sports cars supplied one in MT75 variant
mcerd1
| posted on 15/10/10 at 04:45 PM |
the front uprights on the granada are a different size - so if you don't want to mess about with the geometry then you'll need some sierra
front hubs
that'll leave you with 4 stud fronts and 5 stud rears - but if you can find a set of 4 stud rear hubs they are a strait swap
or you can make the 5 stud front hubs fit in the sierra uprights with just a little tweak in the lathe (should cost less than £20 to get done)
also the steering rack and column are different from the sierra but I don't know if they cause a problem (someone was selling a column on here
the other day)
Andy_B
| posted on 15/10/10 at 06:09 PM |
Cheers for that what sort of geometry changes would be needed ? would it be in the fabrication of wishbones ? lathe work not a problem engineering
background and access to mills and lathes a plenty ...even a coded welding instructer for a wee bro !!
austin man
| posted on 15/10/10 at 08:15 PM |
Dump the engine as well your probably better with a pinto as a minimum or a zetec. Starter motor fits the zetec engine
Andy_B
| posted on 15/10/10 at 08:20 PM |
Thanks for that so i would only be using the Box !! think i will stick with the engine box combo until i have built it... been informed i can make
mushrooms to suit uprights ...doing this on a very tight budget with an 8 year old apprentice !!
daniel mason
| posted on 15/10/10 at 08:40 PM |
it depends on budget! not many people manage to stick to a budget. would be cheaper in the end to go down the tried and tested route! especially when
secon hand parts are readily available. dont ask me how i know.
austin man
| posted on 15/10/10 at 09:43 PM |
the engine is limited for upgrades and power unlike the zetec and pinto there are plenty of tunning opportunities available. A few people have used
the hubs and breaks so that shouldnt be a problem neither should the steering if its not power assisted
mcerd1
| posted on 15/10/10 at 11:38 PM |
sorry I'm not sure exactly, but I know the mushrooms need to be bigger and the upright is a bit taller (not sure if you can sort that in the
mushroom or not)
using the sierra ones is just a little easier and shouldn't cost much:
Ford Sierra front hubs, 2wd on eBay (end time 17-Oct-10 16:57:19 BST)
http://cgi.ebay.co.uk/Ford-Sierra-Front-Hubs-/250709471430?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a5f72f0c6
(the granada brakes are fine either way)
[Edited on 15/10/2010 by mcerd1]
mcerd1
| posted on 19/10/10 at 09:55 AM |
http://www.locostbuilders.co.uk/viewthread.php?tid=144794
